Click around on the net with the $6 AmazonBasics Compact Wireless Mouse at its best ever price
Amazon has its AmazonBasics Compact Ergonomic Wireless Mouse on sale right now for $6.35. This deal takes $10 off its usual going rate and makes for the product's lowest ever price. Just the silver model has reached this new low price, though you can pick up the purple version for just a couple of dollars more.
AmazonBasics Metal Laptop Computer Desk Stand - Silver, 6-Pack
$82.43 $104.98 Save $23
AmazonBasics height-adjustable standing desk converter
$154.43 $180.13 Save $26
AmazonBasics Mini DisplayPort to DisplayPort Adapter Computer Cable - 6 Feet, 10-Pack
$44.90 $49.56 Save $5
$78.47 $104.98 Save $27
AmazonBasics DisplayPort to DVI Display Adapter - 10-Pack
$51.48 $54.60 Save $3
Then again, there's a slightly smaller AmazonBasics wireless mouse on sale for $5.14 in black that might fit your needs just fine. However, the mouse above features fast scrolling whereas this option doesn't.
The AmazonBasics compact ergonomic wireless mouse comes with a small USB receiver that you plug into your computer's USB port to enable the wireless connection. It's equipped with forward and back buttons for your thumb, along with a fast-scrolling click wheel. It can work wirelessly from up to 33 feet away from the receiver and uses AES-128 encryption to stay secure. Its laser sensor is capable of working properly on most surfaces, including glass. The mouse is compatible with Windows 7, 8, and 10, and requires one AA battery to power on. AmazonBasics includes a one-year limited warranty with its purchase.
Over 250 customers at Amazon reviewed this mouse resulting in a rating of 4 out of 5 stars.
