Control your lights from anywhere with three TP-Link smart switches down to just $55
You are now subscribed
Your newsletter sign-up was successful
B&H has the three-pack of TP-Link Kasa smart Wi-Fi light switches on sale for $54.99 today meaning you can smarten up your home lighting for less. Regularly, just one of these switches would cost around $30 at Amazon (though they are $25 each there right now) and this deal for the three-pack beats the last one we posted by a few bucks, too. The offer is part of B&H's DealZone so is limited to one day only.
TP-Link Archer AX3000 Wi-Fi 6 wireless router
$99.00 $130.00 Save $31
Wi-Fi 6 promises speeds up to three times faster than previous generations with four times the bandwidth capacity and 75% lower latency. The router has MU-MIMO tech to cover multiple devices connected at once and Ethernet for wired connections.
TP-Link Kasa KP400 smart outdoor plug 2-pack
$29.99 $50.00 Save $20
Get free shipping with your Prime membership. Each plug has two outlets that can be controlled together or individually. Use your phone or voice control with Google Assistant or Amazon Alexa to control them from anywhere. Weather resistant.
TP-Link Archer A20 AC4000 Tri-Band Wi-Fi router
$139.99 $200.00 Save $60
With a tri-band radio, MU-MIMO technology, Beamforming, link aggregation, and more, this router is perfect for homes with a dozen different devices all trying to connect at once. It supports Windows, Mac, and Linux. Includes a 2-year warranty.
$16.99 $25.00 Save $8
With two outlets you can control two outdoor devices either together or individually. And you can do it from anywhere using your phone or voice control through Google Assistant or Amazon Alexa. Weather resistant with long Wi-Fi range.
TP-Link Archer C7 AC1750 Wi-Fi 5 dual-band router
$49.99 $80.00 Save $30
This great little budget router is capable of data transfer speeds up to 1750 Mbps with 2.4GHz and 5GHz wireless bands. Also has four Ethernet ports for a wired connection. Includes a quick and easy setup wizard.
The switches work with Amazon Alexa and Google Assistant for voice control, and you can also control them using your smartphone via the free Kasa app. There's no need to purchase an additional hub to make them work, just hook them up to your Wi-Fi network.
Use these smart switches to turn your lights on or off from anywhere in the world. You can also set automated schedules and use Away Mode to turn devices on and off at different times to give the appearance that someone is home. Note that they requires a neutral wire and works in a single-pole setup only. Be sure to refer to the user manual and installation guide before use. TP-Link backs these up with a two-year warranty.
