Temple Run updated to address compatibility issues with Android 4.0 devices
If you've been having any sort of issues playing Temple Run on your Android device now would be a good time to check for updates. The team at Imangi Studios has now released the latest update to the game and it has plenty of bug fixes and improvements added that will hopefully make the in-game experience better for all.
  • Fixed many compatibility issues with Android 4.x ICS devices
  • Fixed bug that caused low resolution textures to be used on high DPI devices
  • General bug fixes and improvements
Personally, I never had any issues with it on my Galaxy Nexus in the past but there seems to of have been enough reported concerns for Imangi Studios to correct whatever the issues were. If you had issues try out the latest build and see how it works. Remember, if you're still experiencing problems -- reach out to the developers. They're openly asking for feedback so give it to them if need be. As always, download link is below in case you've not yet checked out Temple Run.
