Take off 40% on four Aoycocr smart LED light bulbs
Aoycocr Bulbs
Aoycocr Bulbs
Time to add a little smarts to those lights you don't normally smarten up. This four-pack of Aoycocr BR30 dimmable smart LED light bulbs is down to $29.69 on Amazon. Clip the 5% off on-page coupon, then use the code 404SLS5Q during checkout. The two discounts will stack to bring these bulbs under $30 for the first time. Without the codes, the bulbs are selling for $54, which is what they normally go for. You're saving just over $24 with today's deal.
Smart Lights Led Bulb Daylight Aoycocr(6500K) 7.5W A19 - Medium Screw Base (E26) - 750 Lumens(65W equiv.) - Dimmable - RGB Color Changing - Voice Control - No Hub Required - UL Listed - 4 Pack
$20.99 $40.99 Save $20
Aoycocr Smart Light Switch
Starting at $10
These smart light switches can be controlled using an app on your phone or even with your voice! Amazon's offering an additional 50% off which shows at checkout; you can grab one for $10 or two for just $17!
Aoycocr Mini Smart Plug (4-pack)
$19.79 $31.06 Save $11
These smart plugs can be controlled using an app on your phone or tablet, or even with your voice! No hub is required, and today's sale saves you 40% at checkout instantly. That brings them down to just $5 each.
$19.79 $32.99 Save $13
Appliances you already own can be controlled with your phone with help from these mini smart plugs. Adding to your cart via this link scores you 1 for $7.79 or 4 for under $5 apiece.
Aoycocr BR30 dimmable LED multi-color smart bulbs 4-pack
$33.59 $53.00 Save $19
Aoycocr's BR30 smart bulbs are perfect for recessed lighting fixtures and anywhere you need some directional smart lights. Don't require a hub and work with Amazon Alexa and Google Assistant. Set schedules and routines with the free smartphone app.
These are BR30 light bulbs, and that's an important distinction. They are not designed to replace regular bulbs in a floor lamp or similar device. The BR30 design works best with lights that are in a recess or hanging upside down from the ceiling. If you want lights that are meant to be upright, look for the A19 designation.
That being said, these bulbs can add a whole lot of functionality to your home. They don't require a hub or anything, so they can connect directly to your Wi-Fi network. Because of that you can also connect these bulbs straight to your smart home ecosystem. Whether you use Google or Amazon, you can activate these smart bulbs using just your voice. Use Alexa or Google Assistant to turn them on or off, dim the brightness, or even change the color.
Download the free Smart Life app on your phone or tablet. You can control them remotely with just the press of a button or two.
These are fully multi-color bulbs with 16 million colors to choose from. Set the right atmosphere for movie night or set them to full bright white while you're working. You can even create your own scenes or routines that match what you do in that room, whether that's hosting a party or playing video games. Tune the lights to the perfect color temperature from warm to daylight. Match the white color of the previous bulbs or make it nice and cozy.
