Take $100 off Dell's 32-inch curved HDR FreeSync monitor at Best Buy
The Dell S3220DGF 32-inch curved FreeSync monitor has dropped to $349.99 at Best Buy. This monitor normally sells for $450, and that's the price you'll find it selling for directly from Dell.
Dell New XPS Special Edition prebuilt desktop computer
$1165.22 $1700.00 Save $535
You can customize this desktop and add some extras like Office 365 or antivirus. The specs include an Intel Core i7 processor, 16GB DDR4 RAM, a 512GB M.2 NVMe SSD, a 1TB 7200 RPM hard drive, and a Nvidia GeForce RTX 2060 graphics card.
Dell S2721DGF 27-inch 1440p 165Hz gaming monitor
$377.99 $430.00 Save $52
Specifications include a native 1440p pixel resolution, a refresh rate that goes up to 165Hz on DisplayPort, and a 1ms response time even though it features an IPS panel with great viewing angles and color accuracy. Includes USB 3.0 hub.
Dell Summer sales event on computers and electronics
Various Prices
Exclusive online doorbusters will start around 11 a.m. Eastern, but many deals are already live including discounts on laptops, all-in-one PCs, and prebuilt desktop computers. Plenty of accessories like mice, keyboards, and monitors on sale as well.
Dell S2721DGF 27-inch 1440p gaming monitor black
$379.99 $430.00 Save $50
This is a top notch gaming monitor. It has a native 1440p resolution with a refresh rate up to 165 Hz and a 1ms response time. Has an IPS panel with great viewing angles and colors. Includes two HDMI, one DisplayPort, and a USB 3.0 hub.
$636.99 $865.00 Save $228
This is a limited sale that's bound to run out sooner than later. It has a 10th-generation Intel Core i5 4.5GHz processor, a Nvidia GeForce GTX 1650 Ti graphics card, a 256GB NVMe SSD for storage, and 8GB RAM. It also has a 15.6-inch 1080p display.
So this monitor is actually relatively new. It was just announced by Dell in August last year, and the earliest reviews showed up around October. We haven't seen a lot of deals on it since that time, which is normal for an advanced display like this. Today's discount from Best Buy might be the first time it has been this low, and it's definitely the best deal we've ever seen.
The 32-inch display has a ton of great features going for it. The basic specifications include a Quad HD 2560 x 1440 pixel resolution with a 16:9 aspect ratio, a 165Hz refresh rate, and a 4ms response time. The monitor also has 400 nits of brightness with VESA DisplayHDR 400 technology, which means it can support and watch HDR content, which helps make movies and games much more lifelike with striking colors.
The curve of the screen helps keep you immersed in whatever you're doing. Plus, it creates a cool wrap-around effect if you decide to stack more than one screen. Although, with 32 inches to work with I'm not sure you'll need two monitors. You can also use AMD's FreeSync 2 technology to match the frame rate of the monitor with your AMD graphics card and get some smooth gameplay.
There are plenty of great connectivity options in this monitor. It has one DisplayPort and two HDMI inputs. Plus, it has five USB 3.0 ports, including one for upstream and four for downstream.
It uses a VA panel with 178-degree viewing angles, and there is also a 100mm x 100mm VESA mount on the back so you can attach it to the wall or an arm.
