The best Android tablets for drawing in 2026
The Samsung Galaxy Tab S11 and S11 Ultra.
(Image credit: Brady Snyder / Android Central)
While nothing quite beats a pen, pencil, or paint on paper for artistry, there's a lot you can do nowadays using digital technology. And there are some Android tablets that are especially great for drawing, whether you're a novice or a professional sketching out ideas and making digital creations.
Along with access to drawing apps, some of the best Android tablets for drawing have drawing features and apps baked in. Many also come with a digital stylus that provides advanced capabilities and a real pen-on-paper feel.
The Samsung Galaxy Tab S11 Ultra remains the best Android tablet for drawing. It doesn't reinvent the wheel, but it's mighty powerful thanks to its new processor, and has an anti-reflective finish for better eye comfort. There are other Samsung models if you're on a tighter budget, and several good ones from other brands too. Don't forget to check out the best drawing tablets if you're fine without Android.
At a glance
Spec overview
Swipe to scroll horizontally
Specs
OnePlus Pad 3
Amazon Fire Max 11
Onyx Boox Note Air4 C
Samsung Galaxy Tab S10 FE
Wacom One 12
Display
14.6-inch (2960 x 1848) AMOLED
13.2-inch (3392 x 2400) LCD
11-inch (2000 x 1200) LCD
10.3-inch (2480 x 1872) Kaleido 3 E Ink
10.9-inch (2304 x 1440) LCD
12-inch (1920 x 1080) LCD
Chipset
MediaTek Dimensity 9400+
Qualcomm Snapdragon 8 Elite
MediaTek MTK8188J
Octa-core + BSR
Samsung Exynos 1580
Unspecified
Memory/Storage
12GB, 16GB
256GB, 512GB, 1TB
12GB
256GB
4GB
64GB, 128GB
6GB
64GB
8GB, 12GB
128GB, 256GB
Unspecified
Battery
11,600mAh
12,140mAh
7,500mAh
3,700mAh
8,000mAH
Unspecified
Dimensions
208.5 x 326.3 x 5.1mm
209.7 x 289.6 x 6mm
259.1 x 163.7 x 7.5mm
226 x 193 x 5.8 mm
254.3 x 165.8 x 6.0mm
299 x 190 x 11mm
Weight
692g
675g
490g
420g
497g
680g
Best overall
Best overall
Specifications
Display : 14.6-inch (1848 x 2960 pixels) Dynamic AMOLED 2X, 120Hz, 16:10 ratio
Processor : Mediatek Dimensity 9400+
Memory: 12GB, 16GB
Storage: 256GB, 512GB, 1TB
Cameras: Rear: 13MP (wide) + 8MP (ultrawide); Front: 12MP (ultrawide)
Battery: 11,600mAh
Stylus : S Pen included
Dimensions: 326.3 x 208.5 x 5.1mm
Reasons to buy
One of the most powerful tablets available
Massive 14.6-inch display
S Pen included
IP68 water and dust resistance
Reasons to avoid
Very expensive
Screen might be too large for some
The Samsung Galaxy Tab S11 Ultra lives up to every bit of its name with some of the most powerful hardware ever packed into an Android tablet. It's the 2025 refresh of the Galaxy Tab S10 Ultra, and Samsung hasn't changed a lot. We again have a MediaTek chip at the helm, a change Samsung first made with the Tab S10 series. It still costs the same, so you might as well get the latest model and an extra year of OS upgrades instead of the Tab S10 Ultra.
There's no question that the Tab S11 Ultra is an expensive tablet, but you end up with a device that can just about replace a laptop in functionality. If you travel a lot, the massive TV-like screen can be great for catching up on YouTube videos or even watching movies. And thanks to Wi-Fi 7 support, you'll have sufficient wireless speed for streaming high-quality video.
The Galaxy Tab S11 Ultra has a Mediatek Dimensity 9400+ SoC with 12GB or 16GB of RAM, depending on the storage you pick. It has a massive 14.6-inch AMOLED display with a 120Hz refresh rate, which allows for plenty of space for an 11,600mAh battery that can be charged at up to 45W.
Naturally, an S Pen is included in the box, so you can start drawing just as soon as the tablet is set up. The stylus is also IP68-rated and has enhanced sensitivity for fewer accidental clicks. It can be magnetically attached to the tablet for charging.
Samsung Galaxy Tab S11 Ultra scorecard
Attribute
Quick look
Score
Display
Outstanding and huge
Performance
Top-tier performance for multitasking and gaming
Value
Too price-y for casual use
Stylus
S Pen included
Battery life
Over 10 hours with heavy use; fast charging
Best alternative
Notes app - OnePlus Pad 3
(Image credit: Andrew Myrick / Android Central)
Best alternative
Specifications
Display : 13.2-inch (3392 x 2400 pixels) AMOLED, 144Hz
Processor : Qualcomm Snapdragon 8 Elite
Memory: 12GB
Storage: 256GB
Cameras: Rear: 13MP (wide); Front: 8MP (wide)
Battery: 12,140mAh
Stylus : OnePlus Stylo 2 (sold separately)
Dimensions: 289.6 x 209.7 x 6mm
Reasons to buy
S Pen included
Updated S Pen features 2.8ms latency
Fantastic size for portability
Super AMOLED display with 120hz refresh rate
Routinely found on sale
Reasons to avoid
Misses out on some of the newer AI features
Likely to soon be replaced
When comparing the OnePlus Pad 2 to the Pad 3, it might seem like the price jump is a bit steep. But that couldn't be further from the truth when comparing the Pad 3 to the Galaxy Tab S11 Ultra. The latest OnePlus tablet is $500 cheaper, but since the Stylo 2 isn't included in the box, let's just say it's $400 less.
With that, you're getting a gorgeous 13.2-inch display with a 144Hz refresh rate and an LCD panel. This makes it an obvious choice for those who suffer from PWM and can't use OLED tablets but still want a flagship Android tablet.
Thankfully, there are very few issues in that department, with the OnePlus Pad 3 being powered by the Snapdragon 8 Elite. It's paired with 12GB of RAM and 256GB of storage, which is a bit of a bummer as there's not even a built-in microSD card slot.
Much like the Tab S11 Ultra (and practically every other phone or tablet), OnePlus integrated a bunch of AI features into the Pad 3. These include the usual Gemini-powered suspects, but OnePlus offers a few features of its own to try and help perform various tasks for you.
OnePlus Pad 3 scorecard
Attribute
Quick look
Score
Display
Glorious AMOLED with 144Hz refresh rate
Performance
Elite
Value
Flagship package at an affordable price
Stylus
Battery life
Up to 18 hours with casual use
Best budget
Recent apps on Amazon Fire Max 11
Best budget
Specifications
Display : 11-inch (2000 x 1200 pixels) IPS LCD, 5:3 ratio
Processor : Mediatek MT8188J
Memory: 4GB
Storage: 64GB, 128GB
Cameras: Rear: 8MP (wide); Front: 8MP (wide)
Battery: Up to 14 hours
Stylus : Included
Dimensions: 259.1 x 163.7 x 7.5 mm
Reasons to buy
High-resolution 11-inch display
Strong battery life
Good performance for an Amazon tablet
Low price
Reasons to avoid
Amazon software won't be to everyone's liking
Play Store must be side-loaded
Amazon has a distinct advantage in pricing hardware since the company makes up much of the cost in in-app sales, subscriptions, and, of course, lock screen ads. As a result, the Fire Max 11 punches well above its weight with a large 11-inch display running at a 2000 x 1200 resolution.
It comes with 4GB of RAM and a MediaTek MTK8188J SoC, so it's not going to have the maximum Genshin Impact, but our Fire Max 11 review notes that it has some of the best performance of any Amazon tablet. The display has a 60Hz refresh rate, which won't feel as smooth under a stylus, but it's an IPS panel, so it's bright with vibrant colors.
This bundle includes a stylus made for the tablet, but you can also use another USI 2.0 stylus if you've already invested or want something with different ergonomics. Amazon includes ads on your lock screen, but if you want them removed, you can pay a bit more for the same tablet. You can also remove lock-screen ads later by paying the difference if you're on a budget.
Amazon Fire Max 11 and Stylus Pen bundle scorecard
Attribute
Quick look
Score
Display
11-inch screen, decent resolution
Performance
Good for the money
Value
Great bang for the buck, and discounts are common
Stylus
Included in the bundle
Battery life
Up to 14 hours
Best E Ink display
Onyx Boox Note Air 5 with keyboard cover
(Image credit: Namerah Saud Fatmi / Android Central)
Best E Ink display
Specifications
Display : 10.3-inch (2480x1872 pixels) Kaleido 3 Carta 1200 glass screen
Processor : Octa-core processor
Memory: 6GB
Storage: 64GB
Cameras: None
Battery: 3,700mAh
Stylus : Boox Pen3
Dimensions: 226=5 x 192 x 5.8 mm
Reasons to buy
Android 15 with Google Play Store
Minimum 3 years of updates guaranteed
Performs better, even with the same processor and RAM
Smooth navigation and gestures
Upgraded stylus
Reasons to avoid
You need to buy the keyboard case separately
It's not that different from the Note Air 4 C
The market for E Ink tablets has exploded over the past couple of years, largely thanks to the Boox lineup. Our favorite Onyx Boox Note Air 3 tablet received a minor update in 2024 with the new Onyx Boox Note Air4 C. In early 2026, the Onyx Boox Note Air 5 C arrived, and while it's largely an iterative update with almost identical specs, our reviewer says it somehow performs better, with even smoother navigation, no glitching, and a faster fingerprint scanner.
You also get Android 15 versus 13 with longer app support, a redesigned stylus Pen3, and pogo pins for connecting an optional magnetic keyboard cover. But you do have to buy this keyboard separately, which bumps the cost up if you want to get the entire setup. For the extra $30 for the tablet itself, it's worth it, and you can spend the additional $110 for the keyboard cover only if you need it. But if you're on a very tight budget, the Onyx Boox Note Air 4 C is still a solid option to consider, too.
With both, you get a faster processor, more RAM, and a lighter design compared to the Note Air 3. The improved display affords richer colors and quicker response time. It's well built and sturdy and you can continue to access popular services like BOOXDrop, BOOXDrop Screen Mirroring, Kids Mode, Split Screen, and more. The Pen3 that comes with the Note Air 5 C is slimmer, smoother, and more streamlined, says our reviewer, which makes it more comfortable to hold and use.
The massive E Ink Carta 1200 display is great for reading and sketching. While Boox has its own built-in note-taking application, the fact that it is powered by Android 15 and has the Play Store pre-installed means that you can download any drawing app of your liking. The tablet is built for artists at its core, and ships with some interesting AI-driven 'Smart Scribe' tool. There's a Shape tool for cleaning up artwork, while the Link tool allows designers to attach notes to their creations.
Onyx Boox Note Air 5 C scorecard
Attribute
Quick look
Score
Display
Color E Ink screen with decent resolution and paper-like finish
Performance
Faster processor promises about 50% better performance than the Air3 C
Value
Typically retails around $499, which is a bit pricey
Stylus
Included stylus
Battery life
Multiple days
Best S Pen value
Lifestyle image of someone playing games on the Galaxy Tab S10 FE
(Image credit: Samsung)
5. Samsung Galaxy Tab S10 FE
Best S Pen value
Specifications
Display : 10.9-inch (1440 x 2304 pixels) IPS LCD, 90Hz, 16:10 ratio
Processor : Exynos 1580
Memory: 8GB/12GB
Storage: 128GB, 256GB
Cameras: Rear: 13MP (wide); Front: 12MP (wide)
Battery: 8,000mAh
Dimensions: 254.3 x 165.8 x 6 mm
Reasons to buy
Includes an S Pen
Strong battery life
Water and dust resistant (IP68)
A 5G variant is available
Reasons to avoid
It has a TFT LCD display
Cameras aren't great
If you don't want to spend a ton of money but still want access to Samsung's excellent S Pen features, the Galaxy Tab S10 FE is a good starting point. This tablet has a 10.9-inch display that runs at 90Hz, so it feels reasonably responsive under the stylus.
You get this tablet with Wi-Fi, but if you're willing to spend a bit more, there is a cellular version. It's powered by Samsung's Exynos 1580 SoC, which can keep up with everyday tasks like reading, browsing, or drawing just fine but will struggle with 3D gaming.
Along with upgraded internals, Samsung also took the opportunity to introduce a better display. Its predecessor featured a rather pedestrian (and outdated) TFT LCD, but the Tab S10 FE is equipped with an IPS LCD.
While it's not an OLED display, you still won't be disappointed when it comes to drawing, sketching, writing, notes, or just playing games. And on top of all of that, Samsung is still including the S Pen in the box.
Samsung Galaxy Tab S10 FE scorecard
Attribute
Quick look
Score
Display
Only 90Hz, but still quite nice
Performance
Decent for casual use; not recommended for gaming
Value
Regularly discounted these days
Stylus
Included S Pen
Battery life
Easily surpass 10 hours, fast charging
Best add-on display
Wacom One 12 with pen lifestyle image
(Image credit: Wacom)
6. Wacom One 12
Best add-on display
Specifications
Display : 11.6-inch (1920x1080) IPS
Processor : N/A
Memory: None
Storage: None
Cameras: None
Battery: None
Stylus : Wacom One Standard Pen
Dimensions: 299.72 x 190.5 x 10.16 mm
Reasons to buy
Easy plug-and-play solution for drawing
Can be used with Android tablets, smartphones, and Chromebooks
Pressure-sensitive pen included
13.3-inch display makes it feel like you're drawing on paper
Reasons to avoid
Not actually an Android tablet
The Wacom One 12 is a bit of a cheat entry since it's not technically an Android tablet. This dedicated drawing tablet provides a plug-and-play experience across pretty much any device. It's even possible to use it with the best Android phones, as well as Windows, macOS, Android tablets, and Chromebooks.
With the Wacom One 12, you get an 11.6-inch display with a 1920 x 1080 resolution. In the box, Wacom includes the tablet itself, the Wacom One Standard Pen, a power adapter, two USB-C cables and the quick start guide. So basically, you'll get everything you need to hit the ground running. Plus, pressure-sensitive pen and is designed so that you shouldn't get fatigued as easily as using other stylus options.
It's easy to understand why the Wacom One 12 is our pick for the best drawing tablet overall, especially since the brand has been making some of the best in that market for years. With support for many devices across various platforms, the Wacom One may not run Android. Still, it's a highly compelling option if you're serious about drawing and have other Android devices at home or work.
Wacom One 12 scorecard
Attribute
Quick look
Score
Display
Big and beautiful 13.3-inch
Performance
N/A
Row 1 - Cell 2
Value
A bit price-y for casual users
Stylus
Feels just like ink on paper
Battery life
N/A
Row 4 - Cell 2
How to choose
These are the best Android tablets for drawing
While Samsung's tablets dominate the list of best Android tablets for drawing, it's for a good reason. With tablets like the Galaxy Tab S10 FE and Tab S11 Ultra, you have a stylus in the box, and Samsung continues innovating. Having a latency as low as 2.8ms is absolutely incredible, and when paired with the best drawing apps, these tablets are second to none. They also have some of the best displays with AMOLED panels and 120Hz refresh rates.
However, outside of the stylus-specific features, the gap between Samsung and other Android tablets is getting slightly smaller. For example, the Amazon Fire Max 11 has some incredible hardware for the price. While its Fire OS software won't be to everyone's taste, you can still side-load the Play Store. You can bundle it with a pen or buy it alone and grab a USI 2.0 stylus down the line.
What is USI 2.0?
USI 2.0 stands for Universal Stylus Initiative (USI) 2.0, and it's an open standard for active styli that allow a stylus to function with various touch-enabled devices.
While Samsung's S Pen is impressive, it's disappointing that it can't be used with more devices. USI 2.0 is a standard that addresses the problem of proprietary styli, a single standard that companies like Google can use to add high-end stylus capabilities to their products. The Google Pixel Tablet, for example, supports USI 2.0, so you can use a stylus like the Penoval USI 2.0 Pen with 4,096 pressure points.
This standard has also made its way to several other devices, including some of the best Chromebooks. Just be sure you pick one of the best styli with USI 2.0 support to get the complete feature set.
Andrew Myrick
Senior Editor — Smartphones (North America), Chromebooks & Tablets
Andrew Myrick is a Senior Editor at Android Central. He enjoys everything to do with technology, including tablets, smartphones, and everything in between. Perhaps his favorite past-time is collecting different headphones, even if they all end up in the same drawer.
With contributions from
