Switch to wireless charging for 2020 with the $8 Anker PowerPort 5 pad
It's the start of a new decade, and if you're not wireless charging your phone already, it's time to seriously consider changing your ways and adding 'start wireless charging' to your New Year's to-do list. More and more phones are Qi-enabled these days, and it's likely you own one already. You can stop plugging your phone in every time you need to power up and switch to something like Anker's PowerPort 5 Wireless Charging Pad instead. Today it's on sale for only $7.99 at Amazon when you enter promo code DMAKA258 during checkout. That saves you $10 off its price otherwise and brings this wireless charging pad lower than it's ever reached without a code before.
Anker Soundcore Life Q30 hybrid active noise-cancelling Bluetooth headphones
$59.99 $79.99 Save $20
These hybrid Bluetooth headphones reduce ambient noise up to 95% thanks to active noise-cancelling mics. The battery lasts up to 40 hours with ANC on or 60 hours with it off, and recharge via USB-C. Clip the $20 on-page coupon.
Anker Powerline II 6-feet USB-C to Lightning cable
$12.74 $15.00 Save $2
When using a USB-C power adapter (not included), you'll get the fastest possible charge for your iPhone. Plus you can seamlessly sync and charge your Mac. This is Apple MFi certified and lasts 12 times longer than other cables.
Anker Liberty Air 2 Pro true wireless earbuds Best Buy
$79.99 $130.00 Save $50
These earbuds have active noise-cancelling that's customizable with a simple app. You'll get a total of 26 hours of playtime with seven hours from a single charge and the rest from the charging case. Uses USB-C and has wireless charging.
Anker Soundcore Rave Neo portable Bluetooth speaker with LED lights
$84.99 $120.00 Save $35
Includes a rechargeable battery that will last for up to 18 hours and can charge other devices with the USB port. IPX7 rated for water resistance. The built-in LED lights will sync to the music you're playing. Connect multiple speakers together.
Anker Soundcore Liberty 2 Pro true wireless earbuds black
$49.99 $100.00 Save $50
They last for up to eight hours on a single charge with up to 32 hours total using the charging case. They have quick charge so you can get two hours after 10 minutes spent charging. They also charge via USB-C or a Qi wireless charger.
This 5W wireless charging pad works with nearly all Qi-enabled devices, from smartphones like the latest iPhone and Samsung devices to the Apple AirPods and more. It can even charge through your phone case, as long as it's not 5mm wide or thicker. Magnetic or metal attachments that you may have added to help with mounting your phone in your car will also get in the way of charging properly.
Anker's PowerPort 5 is equipped with an advanced chipset which Anker says can charge your devices 10% faster than other 5W wireless chargers. There are also built-in safeguards such as overvoltage protection, temperature control, foreign object detection, and more. Anker even includes an 18-month warranty with its purchase, as well as a 3-foot micro USB cable. However, you won't receive a USB wall adapter to plug it into, so you may want to add one to your cart before checking out if you don't have a spare at home. This pick from AmazonBasics is just $7 at Amazon.
Shipping at Amazon is free on orders totaling $25 or more, or with an Amazon Prime membership. If you've never been a member before, you can start a free 30-day trial to score free two-day shipping with no order minimum, as well as perks like exclusive members-only discounts, access to the Prime Video streaming service, and more.
Be an expert in 5 minutes
