Is Surface Duo feeling sluggish? Here are two tips to help speed it up.
Surface Duo 2020
Surface Duo 2020 (Image credit: Daniel Rubino / Android Central)
Android is a demanding OS, and it has been years in the making of it trying to feel as fast and fluid as Apple's iOS. Spoiler: it probably never will feel that good. But that doesn't mean devices like Surface Duo can't benefit from some tweaks. Indeed, while Surface Duo's hardware is excellent, the software needs some fine-tuning.
Here are two simple tricks that should improve the overall fluidity of Android on Surface Duo. One is obvious, the other not so much.
Tip #1: Turn off navigation gestures
Android and gestures have been a challenge. Whether its older Pixels, Samsung, or LG phones, gestures tend to be a bit janky.
By default, Surface Duo uses swipe gestures for navigation. Besides having a learning curve, some people don't like swiping to go back or bring up the app switcher. But you don't have to use that nav gestures at all and can instead rely on virtual buttons for back, home, and app switcher. Here's how:
  1. Go to Settings > System > Gestures > System navigation
  2. Enable 3-button navigation
That's it. Some of you may prefer this navigation method, while others may appreciate how (at least to me) it feels smoother when jumping around between apps. The only real downside is you lose a few pixels of vertical space due to the navbar. Either way, it's good to know your options.
Tip #2: Reduce animation speeds
Animations can look great, but they also tend to tax the system a bit more in addition to technically slowing things down (or at least, giving that appearance).
By default, all Android phones ship with animations at 1x, but you can reduce Window, Transition, and Animator duration scales down to .5x or even turn them off. However, to get the option in settings, you need to enable Android Developer Mode. Here's how.
Warning: There are lots of things you should not touch under developer settings. Use it at your own risk.
  1. Go to Settings > About > Build number (at the very bottom)
  2. Tap 5 times on Build Number
That's it. Now, under Settings > System there is a listing for Developer options.
Now, to reduce animation speed:
  1. Go to Settings > System > Developer Options
  1. Scroll to Drawing
  2. Change Windows animation scale, Transition animation scale, and Animator duration scale to .5x (or whatever you want)
The change is immediate and can always be reset to 1x later.
Wrapping up
Surface Duo is like most other Android devices in that it is far from perfect, but there are also plenty of neat tricks to configure how you want it.
I never use gestures, even on high-end phones like the Samsung Note 20 Ultra, so disabling them on Surface Duo is just a personal preference that benefits from making the OS feel smoother. The same goes for the animation scale trick, which goes back years on Android phones, and I have done on every one of them, including my Galaxy Z Flip. And if you didn't know about these options, at least now you do.
