Sunday's top deals: the GoPro Fusion camera, a dash cam, smart plugs, and more!
GoPro Fusion
GoPro Fusion (Image credit: Android Central)
We've gathered all of the day's best deals on tech and more below to save you having to hunt them down alone. Most are limited in time, so make sure you don't miss out.
GoPro Fusion 360-degree camera - $199.99 (from $250)
The GoPro Fusion 360-degree camera is down to $199.99 at Best Buy as part of the Deals of the Day. That means this is a one-day only sale and won't be around by tomorrow. The same camera goes for $250 at B&H and even more elsewhere. This deal also includes a free dual battery charger along with two spare batteries, which is a deal worth about an extra $100 in value. You won't find that offered anywhere else.
GoPro Hero9 Black 5K 20MP streaming action camera
$349.99 $450.00 Save $100
The Hero9 bumps the action camera's capabilities tremendously. Shoot in 5K video resolution. Use the new 23.6MP sensor for stunning images. SuperPhoto tech processes images for you. HyperSmooth 3.0 stabilizes video. Plus it's rugged and waterproof.
GoPro Hero9 action camera and Adventure Kit bundle
$399.00 $450.00 Save $51
The kit includes The Handler, a floating hand grip for handheld shots, a head strap for point-of-view shots, the QuickClip to attach the Hero9 to your cap or belt, and a compact carrying case. The Hero9 shoots 5K video and 20MP photos.
GoPro Hero8 Black action camera
$249.99 $349.99 Save $100
Hero 8 Black records 4K video, takes 12MP stills, includes HDR support, and more. Record video in slow motion, use TimeWarp 2.0 for stabilized time lapses, and use HyperSmooth 2.0 for video stabilization. Save $100 and score a $20 Best Buy gift card.
GoPro Hero8 Black action camera bundle Costco
$269.99 $340.00 Save $70
The bundle is actually less than the current price of the Hero8 Black by itself. Includes The Handler hand grip camera mount, a spare battery, a 32GB microSD card, and a compact carrying case. The Hero8 has 4K video and 12MP photos.
GoPro Hero 8 Black live streaming action camera bundle
$299.99 $400.00 Save $100
The package includes the GoPro Hero 8 Black action camera, a mini extension pole and tripod called Shorty, a head strap, a SanDisk 32GB microSD card, and a spare rechargeable battery. Get 12MP photos, 4K video, image stabilization, and more.
Yi Nightscape dash cam - $59.99 (from $70)
The Yi Nightscape dash cam is down to $59.99 at Best Buy. That's about $10 off its regular price. You can find it going for a similar price of $59.49 at Amazon if you clip the on-page coupon that saves you 15%, but Best Buy's deal comes with a free 32GB microSD card. Since that is an essential buy to get this dash cam fully functional, you will be saving a bit more money through Best Buy. The Best Buy deal is a temporary one as part of the Deals of the Day section, so it won't last forever.
Yi 4K action camera and 3-axis gimbal stabilizer kit
$109.00 $199.00 Save $90
You can record up to 4K with 30fps or 1080p at 120fps. Capture 12MP photos. Use the electronic image stabilization tech and the gimbal to get perfect shots every time. Includes 360-degree omni-directional mics, Bluetooth, and high-speed Wi-Fi.
Four Yi 1080p W-Fi home security cameras
$89.00 $189.99 Save $101
$99.00 $189.99 Save $91
TP-Link Kasa 4-pack smart plugs - $39.99 (from $45)
TP-Link's Kasa smart plugs are some of the most popular around because of how easy to use and affordable they are. A single plug usually sells for upwards of $18, though thanks to a current sale at Amazon, you can pick up this Kasa Smart Plug 4-pack for only $39.99 right now when you clip the coupon on its product page. That's like picking them up for only $10 each, a deal we've never seen offered on the single plug. This set of smart plugs regularly sells for up to $50.
TP-Link Archer AX3000 Wi-Fi 6 wireless router
$99.00 $130.00 Save $31
Wi-Fi 6 promises speeds up to three times faster than previous generations with four times the bandwidth capacity and 75% lower latency. The router has MU-MIMO tech to cover multiple devices connected at once and Ethernet for wired connections.
TP-Link Kasa KP400 smart outdoor plug 2-pack
$29.99 $50.00 Save $20
Get free shipping with your Prime membership. Each plug has two outlets that can be controlled together or individually. Use your phone or voice control with Google Assistant or Amazon Alexa to control them from anywhere. Weather resistant.
TP-Link Archer A20 AC4000 Tri-Band Wi-Fi router
$139.99 $200.00 Save $60
With a tri-band radio, MU-MIMO technology, Beamforming, link aggregation, and more, this router is perfect for homes with a dozen different devices all trying to connect at once. It supports Windows, Mac, and Linux. Includes a 2-year warranty.
$16.99 $25.00 Save $8
With two outlets you can control two outdoor devices either together or individually. And you can do it from anywhere using your phone or voice control through Google Assistant or Amazon Alexa. Weather resistant with long Wi-Fi range.
TP-Link Archer C7 AC1750 Wi-Fi 5 dual-band router
$49.99 $80.00 Save $30
This great little budget router is capable of data transfer speeds up to 1750 Mbps with 2.4GHz and 5GHz wireless bands. Also has four Ethernet ports for a wired connection. Includes a quick and easy setup wizard.
RAVPower 10W Fast Wireless Charger - $11.99 (from $30)
Use promo code 5PX8H7I7 during checkout. One of the nice things about RAVPower's wireless charging pad is that it comes with a Quick Charge 3.0 wall adapter and the cord you need to connect the pad to the adapter. This is great because it eliminates the need for an extraneous purchase if you don't have a USB port to connect the pad's Micro-USB power cable to. Also, since it's a Quick Charge 3.0 compatible adapter, you know you're getting the fastest possible charge no matter what phone you are trying to charge, even if it's a device that isn't Quick Charge compatible.
Lego Rex's Rex-treme Offroader! building kit - $16.99 (from $30)
Straight from The Lego Movie 2, this building kit is a 3-in-1 action vehicle. It has a dual minifig cockpit and a rotating rear turret with stud shooters. You can rebuild it to create the Rex-o-saurus Quad or the Execu-Rex-o-saurus. There's also a raptor dinosaur figure and a buildable gun to mount. It's a 230-piece kit and works for anyone aged 7 or above.
EasyAcc 26000mAh Power Bank - $22.04 (from $50)
EasyAcc's 26000mAh power bank was designed with tech enthusiasts in mind. Featuring four USB ports and a massive 26000mAh capacity, you'll have no trouble keeping up to four devices charged at once. Today, Amazon has the power bank on sale for as low as $22.04 when you use promo code PNJX99KG during checkout.
That low price also takes into account an automatic 10% discount that only Prime members receive, though you're still snagging a great price today if you're not a member. It saves you up to $28 off this power bank's average cost of $50 there, and it also marks the best price we've ever seen this charger reach.
Doom Eternal video game pre-order - $49.94 (from $60)
The new video game Doom Eternal is set to release on March 20. You can pre-order it right now on Amazon for $49.94, which is $10 off the regular cost of the game. This deal is available for PC, PlayStation 4, and Xbox One. Not only do you get the full game ready for release, you'll also get some other bonuses. Not to mention not having to pay full price when it eventually releases.
Amazon is including a couple of pre-order bonuses with this deal. The first thing you'll get is a copy of Doom 64, one of the original old-school Doom games and a cult classic at this point. You'll also get the Rip and Tear pack, which has some extra in-game content. Use the Doot revenant player skin in Battlemode, the Throwback Shotgun weapon skin, which brings Doom's original shotgun to the newest game, and play a remixed version of the campaign level "Cultist Base" with all new challenges and surprises.
