Sunday's top deals: Dash cams, smart plugs, Bluetooth headphones, and more!
Nightscape Cam
Nightscape Cam (Image credit: Amazon)
We've gathered all of the day's best deals on tech and more below to save you having to hunt them down alone. Most are limited in time, so make sure you don't miss out.
Yi Nightscape dash cam - $59.99 (from $80)
One of Best Buy's deals of the day includes the Yi Nightscape dash cam down to a low price of $59.99. This is a bundle that includes a 32GB microSD card, which is essential to the operation of the dash cam. Normally the set would cost closer to $80.
You can get the Nightscape for around $59.49 at Amazon if you clip the 15% off on-page coupon, but that deal does not come with the microSD card. If you already have a card for storage or want a different brand or something, you could go with that. But for most people the better value is at Best Buy.
Yi 4K action camera and 3-axis gimbal stabilizer kit
$109.00 $199.00 Save $90
You can record up to 4K with 30fps or 1080p at 120fps. Capture 12MP photos. Use the electronic image stabilization tech and the gimbal to get perfect shots every time. Includes 360-degree omni-directional mics, Bluetooth, and high-speed Wi-Fi.
Four Yi 1080p W-Fi home security cameras
$89.00 $189.99 Save $101
$99.00 $189.99 Save $91
Wemo Mini smart plug - $16.99 (from $25)
The Wemo Mini smart plug is down to $16.99 on Amazon. The plug normally goes for as much as $25 and was selling for around $20 for most of the holidays. The drop to $17 is only the third time in the last year it has gone below $20 at all and is just a buck or two from its lowest drop ever. Amazon is actually price matching Best Buy's deal of the day, so you can find the price over there as well. Today's deal will only last through the end of the day.
Bose QC35 II Bluetooth headphones - $220 (from $350)
Read more about the Bose QuietComfort 35 II noise-cancelling Bluetooth headphones in this 4.5 star Android Central review, which called them the best noise-cancelling headphones money can buy. Joe Maring said "I've always enjoyed listening to music, but with these headphones, I find myself wanting to just sit on the couch, throw them on, and close my eyes while listening to some of my favorite tunes."
Govee color changing 4-bulb pack - $11.99 (from $15)
Setting the mood in any room is a lot easier with Govee's color-changing light bulbs. You can switch between 16 vibrant colors using the included remotes, and there are a few cool lighting modes you can select as well. Today you can snag a four-pack of these bulbs on sale at Amazon for just $11.99 when you clip its on-page coupon. That saves you $3 off their usual cost and brings the price of each bulb down to just $3.
Govee Wireless Meat Thermometer
$19.49 $29.99 Save $11
Find out the internal temperature of your food and get remote alerts when what you're cooking hits a desired temperature or falls out of a preset range. Clip the on-page coupon for 15% off and enter the below code at checkout for the full savings.
Govee Smart LED lights
Up to 30% off
The sale includes TV backlighting, LED light strips, interior lighting for your car, smart lights that respond to Amazon Alexa, and more. These are mostly plug-and-play, work with Govee's free smart app, and the LEDs stay cool to the touch.
Govee Smart Lighting Prime Day Sale
From $8
Govee strip lights and LED bulbs are super popular because of their balance of features and price, and several models are discounted by 30% or more at Amazon. The sale also features Govee's home temperature sensors.
Govee 32.8ft Smart Wi-Fi LED Strip Lights
$29.99 $43.99 Save $14
Govee's RGB light strip is easy to setup and can be controlled using an app on your smartphone, or even with your voice! It works with Alexa and Google Assistant and comes in two strips measuring 16.4 feet long each.
Govee Waterproof LED Outdoor String Lights
$39.99 $39.99 Save $0
Soundbuds Slim+ Bluetooth headphones - $22.99 (from $30)
Anker's Soundbuds Slim+ headphones utilize Bluetooth 5.0 to wirelessly connect with devices. With their built-in battery, these headphones can last for up to 10 hours on a single charge and take just 90 minutes to power up fully. They come with various sizes of ear tips and ear wings so you can customize for a better fit as needed.
Featuring IPX7 protection, these fully waterproof headphones defend against rain, sweat, and more. Bring them to the pool or out for a run in the rain. There's a three-button remote built into the wire that lets you skip songs or answer calls using the built-in microphone. You'll receive a carrying case with the purchase as well.
Anker Soundcore Life Q30 hybrid active noise-cancelling Bluetooth headphones
$59.99 $79.99 Save $20
These hybrid Bluetooth headphones reduce ambient noise up to 95% thanks to active noise-cancelling mics. The battery lasts up to 40 hours with ANC on or 60 hours with it off, and recharge via USB-C. Clip the $20 on-page coupon.
Anker Powerline II 6-feet USB-C to Lightning cable
$12.74 $15.00 Save $2
When using a USB-C power adapter (not included), you'll get the fastest possible charge for your iPhone. Plus you can seamlessly sync and charge your Mac. This is Apple MFi certified and lasts 12 times longer than other cables.
Anker Liberty Air 2 Pro true wireless earbuds Best Buy
$79.99 $130.00 Save $50
These earbuds have active noise-cancelling that's customizable with a simple app. You'll get a total of 26 hours of playtime with seven hours from a single charge and the rest from the charging case. Uses USB-C and has wireless charging.
Anker Soundcore Rave Neo portable Bluetooth speaker with LED lights
$84.99 $120.00 Save $35
Includes a rechargeable battery that will last for up to 18 hours and can charge other devices with the USB port. IPX7 rated for water resistance. The built-in LED lights will sync to the music you're playing. Connect multiple speakers together.
Anker Soundcore Liberty 2 Pro true wireless earbuds black
$49.99 $100.00 Save $50
They last for up to eight hours on a single charge with up to 32 hours total using the charging case. They have quick charge so you can get two hours after 10 minutes spent charging. They also charge via USB-C or a Qi wireless charger.
Audible President's Day membership sale - 46% off
With your new Audible membership, which is down to $7.95 for four months, you'll receive a credit each month which can be used towards any audiobook you want. Once you've used a credit to purchase an audiobook, it remains in your library to listen to forever — even when your subscription isn't active. You also have the option of returning any audiobooks after you've started listening to receive your credit back if you're unsatisfied with the purchase.
Along with the one audiobook credit, you'll also get to choose two free Audible Originals each month from a hand-picked selection. There are usually some really interesting picks included, and they can be pretty varied in terms of genre too.
Audible Plus
Audible Plus
$5/month
Audible Plus is a new, more affordable tier at Audible that lets you listen to unlimited audiobooks available in the Audible Plus selection! It normally costs $8 monthly, but right now you can sign up and score six months for only $5 monthly.
Audible 4-month Subscription sale
$7.95 $14.99 Save $7
Amazon's latest discount on Audible is here to save you 46% on your first four months of membership! That brings the monthly cost down to just $7.95 through the end of September, but this deal is only good until June 30 so be sure to sign up now.
Audible 1-year Subscription
$99.50 $149.50 Save $50
Score 12 months of Audible at just $8.29 per month with this limited time offer. You'll receive 1 credit each month to be used toward any audiobook you want, plus two free Audible Originals from a hand-picked selection.
Audible: Free $20 Amazon Credit
Limited Time Offer
Audible members who join before January 31 can earn a free $20 Amazon credit when you listen to three full Audible audiobooks by March 3. The books must be at least three hours long to qualify. You'll receive the credit via email mid-March.
Audible
Audible
$20.85 $44.85 Save $24
An Audible membership earns you 1 credit each month for any audiobook you want, as well as the choice of two Audible Originals from a hand-picked selection. This deal is for new users, though some with previously-cancelled memberships have had luck.
LG 75-inch 4K smart TV - $799 (from $949)
Dell's Presidents' Day sale is not to be missed. With deals on computers, office essentials, smart TVs, and more, you could score hundreds in savings by shopping during the event. Take this LG 75-inch 4K UHD Smart TV for example. It's normally sold for up to $1,130 these days at retailers like Amazon, though during the event you can pick one up on sale at Dell for just $799.
There's much more on sale at Dell this weekend than just this LG smart TV. Be sure to take a look through the full sale to see if there's anything else you might want to add to your order before prices rise back to normal in a few days. You'll want to have something in mind to use that $150 gift card on anyway, as it has just a 90-day window in which to use it before it expires.
