Sunday's best deals: an 82-inch 4K TV, a new Razer mouse, a G-Sync monitor, and more!
We've gathered all of the day's best deals on tech and more below to save you having to hunt them down alone. Most are limited in time, so make sure you don't miss out.
LG 82-inch 4K smart TV - $1,399 (from $1,997)
Use the code TLA27 to take almost $600 off LG's enormous 82-inch 4K TV. In addition to 4K resolutions, you can watch your favorite content with HDR support. The TV supports standards like HDR10, HLG, and Dolby Vision. You can transform the way you listen to your TV, too, thanks to Dolby Atmos support that can make your audio sound like it's coming from all around you. It's a true cinematic experience when you're watching stuff on the LG. LG's smart platform, WebOS, gives you access to all your favorite streaming apps. Access Netflix, Hulu, YouTube, and more. Plus, the integration with LG's advanced AI means you'll get the best possible sound and image settings.
LG 27GL850-B 27-inch Ultragear Nano IPS G-Sync compatible gaming monitor
$386.99 $450.00 Save $63
The specifications include a 1440p pixel resolution, a 144Hz refresh rate, and a 1ms response time. With an IPS panel, you get great viewing angles and color accuracy. Plus the native adaptive sync works with AMD and Nvidia graphics cards.
LG OLED55CXPUA CX Series 55-inch 4K OLED Smart TV 2020 with Alexa
$1,350 + Free Speaker
Deal works with larger TVs, too. The CX series includes an advanced processor for 4K upscaling, LG's webOS smart platform that can access all of your favorite content and streaming platforms, features like G-Sync just for gamers, and more.
LG 27GN800-B 27-inch 1440p IPS Ultragear gaming monitor
$296.99 $400.00 Save $103
A great monitor that includes a 2560 x 1440 pixel resolution, a 144Hz refresh rate, and a 1ms response time. It has an IPS panel for great viewing angles. It's also G-Sync compatible with FreeSync native support.
LG 27GN800-B 27-inch UltraGear 1440p gaming monitor
$346.99 $462.00 Save $115
Add the monitor and an Xbox controller of any color to your cart and you should see $114 taken off when you go to checkout, giving you the controller for free and reducing the price of the monitor to $347, which is what it's going for elsewhere.
LG UltraGear 24GN600-B 24-inch 1080p IPS monitor
$179.99 $220.00 Save $40
This is a model unique to Costco. The monitor has an IPS panel for great color accuracy. It also has a 144Hz refresh rate and 1ms response time. Includes FreeSync, two HDMI ports, one DisplayPort, and wall mounting capability.
Razer Basilisk X wireless mouse - $39.99 (from $60)
The Basilisk X has two connection options: standard wireless or Bluetooth. You'll want to decide what's more important to you in battery life or low latency. While connected via Bluetooth you can extend the battery life of your mouse to up to 450 hours. That's the way to go if you are traveling with the mouse and using it in awkward places like on an airplane or in a hotel lobby or something like that. Keep the mouse going strong for a very, very long time with Bluetooth. If you're gaming with it and want the best possible responsiveness, connect the mouse via wireless and activate that HyperSpeed technology.
Dell 27-inch G-Sync monitor - $299.99 (from $370)
The specifications on Dell's 27-inch LED monitor include a 2560 x 1440 pixel resolution, 144Hz refresh rate, and a 1ms response time. It also has 350 nits of brightness. The connectivity options include HDMI, a DisplayPort, and a USB hub with two USB-A ports. The screen also has 100x100mm VESA wall mounting. If you want to get the highest refresh rate and make use of the adaptive sync technology, you'll want to connect your graphics card to the monitor via DisplayPort.
Oral-B White Pro 1000 electric toothbrush - $34.94 (from $50)
The Oral-B Pro uses 3D Cleaning Action, which oscillates, rotates, and pulses while you brush. This tech helps break up and remove 300% more plaque than regular brushing. It's not just about getting a toothbrush that brushes for you, it's actually about getting a better clean every time. You'll actually improve your teeth more than you thought you could. The toothbrush also has a pressure sensor built into it, which stops the pulsating and other features when you start pressing too hard. A lot of people brush too hard sometimes, so the toothbrush actually saves your teeth and lets you know at the same time when you're doing it.
Oral B Pro 5000 SmartSeries Rechargeable Electric Toothbrush
$70.28 $99.94 Save $30
Oral-B Genius Pro 8000 Electric Toothbrush
$90.00 $179.94 Save $90
$85.00 $179.94 Save $95
$73.99 $99.94 Save $26
Ion Audio portable Bluetooth PA speaker - $49.99 (from $80)
The Sport Go Tailgate portable speaker features a four-inch woofer and a wide-dispersion tweeter with high-fidelity audio. You'll also get 20W peak power for a rich, dynamic sound. It also has a huge rechargeable battery that can last for up to 50 hours. Don't need it for that long? Put the battery to use charging your mobile devices thanks to the built-in USB port. And, of course, the speaker has Bluetooth so you can stream from your favorite music apps while charging at the same time.
ION Audio Tailgater (iPA77) | Portable Bluetooth PA Speaker with Mic, AM/FM Radio, and USB Charge Port
$119.00 $119.99 Save $1
Songmics shelves, benches, modular storage - Up to 35% off
Is your New Year's Resolution to be more organized? Probably not, but it should be! Cause you're a hot mess. Let's do some spring cleaning before it's even springtime. Today Amazon has Songmics storage cubes, shoe racks, desks, and more all on sale for up to 35% off. This is your chance to save on all the storage you need and find a place for all your stuff. Don't be afraid to mix and match the storage. Find something that matches your style and decor.
You'll find modular cube storage shelves, hangers, desks, end tables, and more all down to low prices. The cubes are DIY so you can mix and match and find the best custom shape for you. All from the Songmics brand. All with very positive reviews.
SONGMICS Bamboo Standing Computer Desk Monitor Stand Riser Stand Steady Up Adjustable Height Desktop Laptop Workstation Converter Natural ULLD97N
$67.99 $79.99 Save $12
SONGMICS Laptop Desk for Bed Sofa with Adjustable Tilting Top, Breakfast Serving Tray with Folding Legs ,Multi Function Table, Floor Desk, 100% Bamboo Nature
$23.79 $36.99 Save $13
SONGMICS Ergonomic Gaming office Chair, Height Adjustable Racing Chair, Breathable Surface, with Built-in Lumbar Support, High Backrest, Rocking Function, Black, Blue, UOBG63BQ
$75.99 $75.99 Save $0
$79.99 $79.99 Save $0
SONGMICS 10 Tiers Shoe Rack 50 Pairs Non-woven Fabric Shoe Tower Organizer Cabinet Black 39 3/8" x 11 3/8" x 68 7/8" ULSH11H
$23.80 $49.75 Save $26
Lego Boost Creative Toolbox educational kit - $127.99 (from $160)
The Lego Boost Creative Toolbox is a STEM building kit for kids that includes building and programming a robot. There are actually five multifunctional models, and your kids will learn how to build and code. Vernie the Robot can dance, interact with the Autobuilder, and explore and discover new things. Use the Lego Boost app to get instructions for all the different models. Can be combined with other kits.
Mpow H7 Bluetooth headphones - $14.99 (from $24)
With their memory-foam ear cushions, adjustable headband, and ergonomic design, the H7 headphones, down to $14.99 with code MPOW162A, are comfortable enough to keep you listening for hours at a time. And luckily, the internal battery can last for up to 18 hours on a single charge, though with the included 3.5mm audio cable, you can use them as wired headphones without the battery constraint. The H7 Bluetooth headphones feature 40mm driver units and a CSR chip, along with a built-in microphone. You'll also receive a two-year warranty with this purchase.
Mpow X5 hybrid active noise-cancelling true wireless earbuds
$39.99 $60.00 Save $20
The hybrid active noise-cancellation on these earbuds uses an outward-facing mic to capture the bad noises and an inward mic to monitor the sound reaching your ears, then uses anti-noise to cancel out the bad stuff. Has 32-hour battery with the case.
Mpow MS1 in-Ear Bluetooth Earphones
$16.99 $29.99 Save $13
These true wireless earbuds come with a charging case that keeps them playing for up to 25 hours while you're on the go. There's also a built-in microphone and IPX7 waterproof nano-coating to keep them protected from runs in the rain and splashes.
Mpow H5 Active Noise Cancelling Over-Ear Bluetooth Headphones
$29.99 $49.99 Save $20
Mpow Hybrid Active Noise Cancelling Headphones, Bluetooth Headphones Over Ear [2019 Version] with Hi-Fi Deep Bass, CVC 6.0 Microphone, Soft Protein Earpads, Wireless Headphones for TV Travel Work
$33.73 $52.99 Save $19
$33.73 $53.99 Save $20
