Sunday's best deals: the Echo Studio, Meross smart home products, Eufy RoboVacs, and more!
Amazon Echo Studio
Amazon Echo Studio (Image credit: Daniel Bader / Android Central)
We've gathered all of the day's best deals on tech and more below to save you having to hunt them down alone. Most are limited in time, so make sure you don't miss out.
Amazon Echo Studio - $169.99 (from $200)
The Amazon Echo Studio high-fidelity Alexa-enabled smart speaker is down to $169.99 on Amazon. This is a price match of Best Buy's Deal of the Day, which features the speaker at the same price. Basically that just means you've only got a few hours left on this deal. The Echo Studio normally sells for $200 and outside of some unique bundle deals, we haven't really seen it go on sale much at all. This is its first direct price drop on Amazon.
Ring Video Doorbell Wired with Echo Show 5
$64.99 $139.98 Save $75
The Ring Video Doorbell is bundled with Amazon's Echo Show 5 at over 50% off exclusively for Prime Day. You'll be able to see who's at your door using the Ring app on a myriad of devices, including the Echo Show 5.
Fire TV Stick 4K with 'The Disney Bundle'
Limited Time Only
Exclusively during Prime Day, Amazon is offering Prime members three free months of 'The Disney Bundle' with the purchase of a new Fire TV Stick or Fire Tablet. The Disney Bundle gives subscribers access to Disney+, Hulu, and ESPN+.
Amazon Prime Video Channels
Limited Time Only
Amazon Prime Video lets you add other streaming services as 'channels' to your Prime subscription, and right now select options are down to just $1 per month ahead of Prime Day!
Amazon Echo Devices
Amazon Echo Devices
Prices Vary
Featuring the Echo, Echo Dot, Echo Show 5, Echo Auto, Echo Frames, and more, this sale lets you snap up some Amazon hardware without breaking the bank. These are some of the best prices ever, tough they are just for Prime members.
Amazon Kids+ Family Plan
$0.99 $29.99 Save $29
One of the best deals to come to Amazon Kids+ is now available exclusively for Prime members! Your family can score three months of access for only $1 by signing up before Prime Day begins on June 21.
Meross Smart Home Products - up to 40% off
Today is your day to put the finishing touches on your smart home. You can save up to 40% off Meross smart home products including the famous Meross smart garage door opener, a 4-pack of smart plugs, outdoor plugs with weather resistance, and more! All of these items are being sold by Woot through Amazon, and that's expected because the last couple of times we've seen a big Meross sale it was through the Woot website in the first place. This just eliminates the middleman, gives you Prime delivery, and makes the savings super easy to see.
Grab the Meross smart garage door remote for less than $31 and control your garage door from your phone or with your voice. Other options on sale include 4 smart plugs for just $23, outdoor plugs that are weather resistant, light switches, and more!
Meross dual outlet smart plug 2-pack
$25.99 $34.00 Save $8
Create two outlets with one plug and a compact design that won't block the other socket. Control the plugs and the devices plugged into them with the Meross app. Or use Apple HomeKit, Amazon Alexa, or Google Assistant for voice control.
Meross dimmable multi-color Wi-Fi smart table lamp
$26.99 $45.00 Save $18
The intuitive touch controls on top let you change the color, adjust the brightness, and turn it on or off. Also works with Siri, Alexa, and Google Assistant for voice control. Includes several levels of tunable white and 16 million colors.
Meross Smart Wi-Fi Garage Door Opener
$26.79 $40.00 Save $13
Combine the code with the $10 off on-page coupon for maximum savings. Adds remote and voice control easily to your existing garage door opener and doesn't require any extra hub. Easy to set up with included tools. Get notifications and reminders.
Meross smart Wi-Fi garage door opener remote
$26.79 $39.99 Save $13
This garage door opener lets you control it using an app on your phone, or even with your voice and a compatible voice assistant like Amazon Alexa. Clip the coupon on its product page and use the following promo code to save $13 at checkout.
Smart Garage Door Opener Remote, APP Control, Compatible with Alexa and google Assistant, Multiple Notification Modes, No Hub Needed by meross - Upgrade Version
$49.99 $59.99 Save $10
Eufy RoboVac robot vacuum cleaners - up to 37% off
The least expensive model is the Eufy RoboVac 11S Max, which is going for $169.99. That's down from a regular street price of $258.
The RoboVac 15C is also on sale here with a low price of $179.99 compared to its $260 street price. This matches an all-time low.
The RoboVac 30C is the most expensive option, but it's still going for a measly $189.99, and that's $110 off what it normally sells for.
The models on sale include the 11S, 15C, and 30C. They range in price from $170 - $190. All of them are on sale with the 30C at $110 off its regular price. These are self-charging and good on hard floors and medium carpets. Suction varies.
Eufy cordless stick vacuums and robot vacuum cleaners
As low as $140
Choose from a cordless stick vacuum or a robot vacuum. The cordless vac includes 120AW suction power for 8 minutes or 25 minutes in standard mode. Helpful for getting into tight spaces. The robot has 1300Pa suction and lasts up to 100 minutes.
Eufy Security Wi-Fi 2K resolution video doorbell
$119.99 $160.00 Save $40
You'll get a wireless chime you can use somewhere else in the house to hear the door wherever you are. Has a 2K resolution image with advanced HDR and distortion correction. Includes two-way audio, motion detection, and smart alerts.
Eufy RoboVac 15C Max Wi-Fi connected robot vacuum cleaner
$175.99 $ Save $
Comes with super strong 2000Pa suction so it can pick up even stubborn dirt. BoostIQ feature will even boost the suction when you need it. Lasts for up to 100 minutes. Use the EufyHome app and connect it to your smart home for more control.
Eufy Spaceview Security by Anker baby monitor camera bundle
$129.99 $170.00 Save $40
Has a large 5-inch 720p display for a sharp picture. Let's you see everything your little troublemaker is doing. Can pan 330-degrees and tilt 110-degrees so you can see the whole room. Get instant alerts. Has a range up to 1,000 feet.
Eufy Security SpaceView 720p video baby monitor with night vision
$109.99 $160.00 Save $50
Has a large 5-inch 720p display for a sharp picture. Let's you see everything your little troublemaker is doing. Includes a wide-angle lens for when your baby starts moving around more. Get instant alerts. Has a range up to 1,000 feet in open area.
Rosetta Stone lifetime subscription - $145 (from $200)
Sick and tired of only being able to say hello in one measly language? Want to say hello in a second language?! Well, now's your chance! You can get a lifetime subscription to Rosetta Stone as one of Amazon's deals of the day for just $145. This subscription would normally cost you around $200. This is a huge discount when you consider the 12-month subscription is currently $179 on Amazon. This deal comes in the form of an activation code that you get via email, but you can also choose to get it by mail for the same price if you prefer.
Rosetta Stone Lifetime Access
$179.00 $199.00 Save $20
Rosetta Stone makes it easier to learn a new language, or several, once you're subscribed to an annual or lifetime plan. The latest sale lets you join for as low as $7.99 per month or gain lifetime access for just $179!
Rosetta Stone Mother's Day Sale
Limited Time Only
Various Rosetta Stone memberships are on sale through Mother's Day. Just pick a language (or the unlimited languages service), choose your subscription length, and you could save over 45% off the usual cost in the process.
Rosetta Stone Language Programs
Limited Time Only
Rosetta Stone makes it easy to learn a new language (or several) all from the comfort of your home. Score a 12-month membership for only $7.99 per month or get a lifetime subscription for just $179 today.
Rosetta Stone New Year's Sale
from $8 per month
Rosetta Stone is helping make your New Year's resolution just a bit more affordable with a sale on its language software! You can score 12 months of access for as low as $7.99 monthly or grab a lifetime subscription for $179.
Learn English: Rosetta Stone Bonus Pack Bundle (Lifetime Online Access + Grammar Guide and Dictionary Book Set)
$199.00 $319.00 Save $120
G3 Gaming LED mechanical keyboard - $39.99 (from $80)
The G3 Gaming keyboard, which is discounted using the $40 off on-page coupon, uses Kailh Brown mechanical switches, which are fast and precise. You get low actuation force, accuracy, and some tactile feedback with every button press. The keys are comfortable to hit and, even though Brown switches are quieter than others, you'll hear every keystroke. The keyboard also has anti-ghosting and full n-key rollover, which means no matter how fast you type you'll never lose a keystroke. The keyboard won't forget the keys you typed or skip over them because you pressed too many too quickly.
RAVPower 40W USB Car Charger - $6.99 (from $12
Of all the items you should keep in your vehicle, a USB car charger is firmly at the top of the list. If you use your phone for navigation such as getting directions with Waze, the last thing you need is for your phone to go dead while you're busy driving. Luckily, RAVPower has a 40W USB Car Charger on sale for just $6.99 at Amazon right now. You'll just need to use promo code ECHOQEDX during checkout to snag this low price and save $5 off its usual cost there.
RAVPower 65W 4-port USB Desktop Charging Station
$34.99 $49.99 Save $15
Keep USB ports close by with this 65W USB Desktop Charging Station by RAVPower. It's equipped with two USB-C ports as well as two USB-A ports. Clip the coupon on its product page and use the following code at checkout to save $15.
RAVPower 10000mAh portable charger dual USB power bank
$9.99 $15.00 Save $5
The ultra slim power bank is only 15mm deep, so it's extremely portable. The battery size of 10000mAh is enough for a full charge of even the largest phones. Can charge two devices at once and has built-in safety features to protect them all.
RAVPower 61W Power Delivery 3.0 USB-C 2-port wall charger
$23.39 $30.00 Save $7
Has 61W output with Power Delivery 3.0. Can charge a MacBook in 2.1 hours. Can detect what's plugged in and deliver fastest possible speeds. Wants to be portable with slim, compact design and foldable pins. Includes built-in safeguards.
RAVPower 48W USB-C Car Charger with Power Delivery 3.0 and Quick Charge 3.0
$14.99 $19.99 Save $5
RAVPower's fast dual-port car charger features a 30W Power Delivery 3.0 USB-C port along with an 18W Quick Charge 3.0 USB-A port. Clip its on-page coupon to snag this deal.
RAVPower 25000mAh solar phone charger outdoor portable charger
$21.99 $46.00 Save $24
Use sunlight to recharge this charger's batteries or plug it in via micro USB or USB-C. The 25000mAh capacity is enough to keep all your devices going outdoors. Includes an LED flashlight and SOS mode for emergencies. Waterproof and dust proof.
