Store more data with $45 off the Seagate Expansion 6TB hard drive
You are now subscribed
Your newsletter sign-up was successful
Running out of space? Wish you had just a bit more room for a few more games or some new software? The Seagate Expansion 6TB USB 3.0 external desktop hard drive is down to $74.99 with the code 17260 at Staples. It also comes with free shipping. Staples is already discounting the price of the drive to $95, so the code just takes another $20 off, bringing it to one of the lowest prices we've ever seen.
The 6TB drive sells for around $120 at most retailers like Newegg and the best price anywhere is $114.99 at B&H. Today's drop is even less than the 4TB drive, so it's a huge bargain.
Seagate Expansion 14TB USB 3.0 external desktop hard drive black
$199.99 $250.00 Save $50
I mean, 14TB is a whole lot of space to work with. Works with Windows PCs and connects easily via USB. It's plug-and-play so you don't need any extra software. Comes with an 18-inch USB cable and 18W power adapter. It is covered by a 1-year warranty.
Seagate Backup Plus Slim 1TB portable hard drive Space Gray
$44.99 $60.00 Save $15
This USB 3.0 drive that's backwards compatible with USB 2.0 and works seamlessly between Windows and Mac without reformatting. Has customized backups and folder mirroring. Comes with a year of Mylio Create and 2 months of Adobe Photography Plan.
Seagate Ultra Touch 500GB USB-C portable solid state drive
$74.99 $85.00 Save $10
Designed to be Android Ready so you can easily manage your phone using the included Android app. Has universal compatibility thanks to the USB-C port so it works on Windows and Mac. Lightweight design with fabric cover. Includes 3-year warranty.
Seagate Expansion 10TB external USB 3.0 hard drive
$169.99 $190.00 Save $20
Uses USB 3.0 for connection and fast data transfer speeds. Backwards compatible with USB 2.0. Plug in the power adapter and USB cable and it's good to go. Just drag and drop right out of the box. Works with Windows. Comes with 1-year warranty.
Seagate One Touch 4TB external hard drive
$89.99 $105.00 Save $15
A simple on-the-go USB drive with a minimalist brushed metal enclosure. Works great as a backup or for portable media storage. Comes with a two-year warranty from Seagate. Compatible with Windows and Mac but may need reformatting for Time Machine.
Why pick and choose what you can keep when you can just keep it all? Instantly add tons of space to your computer with this fancy drive that can sit right on your desktop. It's plug-and-play, too, so it's not like you have to out of your way to install anything. Just plug in the power adapter and plug the USB cable into your computer and get to work.
The Expansion will be automatically recognized by Windows computers running Windows 7 and up. You don't even need to install any software. If you're using a Mac, you'll want to reformat the drive when you first get it. Remember that reformatting erases the data, so be sure to do this before you transfer anything to it.
After that, you can take advantage of the USB 3.0 transfer speeds that work up to 5 Gbps. It is even backwards compatible with USB 2.0 so you'll always be able to access it even on older ports and older systems. It's just as easy to use as it is to install. Drag and drop your files from one place to the other and boom you're good to go. Use it as a backup drive, too.
