The SteelSeries Arctis 1 USB-C wireless headset has dropped to $80
SteelSeries Arctis 1 Wireless Gaming Headset
SteelSeries Arctis 1 Wireless Gaming Headset (Image credit: Amazon)
The SteelSeries Arctis 1 USB-C wireless gaming headset is down to $79.99 at Amazon. This is the same price over at Best Buy where the headset is a featured Deal of the Day, which means this price won't be here tomorrow. The headset normally sells for around $100 or more. The PlayStation 4 version is still going for that enhanced price. (All of these headsets are basically the same excep the PS4 version has a different color scheme.)
SteelSeries 61473 Arctis Pro Bluetooth wireless on-ear headset
$239.99 $330.00 Save $90
Includes both 2.4GHz wireless and Bluetooth connectivity. Can also connect via 3.5mm. Has premium speakers with an expansive frequency range. Made with luxurious lightweight steel and aluminum alloy. Has swappable batteries and a base station.
SteelSeries Glow Up all-in-one gaming bundle
$129.99 $200.00 Save $70
Great gift for a first-time PC builder or general gamer. Includes the Arctis 1 wireless headset, Apex 3 keyboard, Rival 3 wireless mouse, and QcK mousepad. Has super fast Quantum 2 wireless tech in the mouse and water resistance on the keyboard.
SteelSeries Arctis 1 wired gaming headset
$34.99 $50.00 Save $15
The wired headset includes a detachable microphone with ClearCast tech to reduce background noise. Produces great sound and has an adjustable headband. Uses 3.5mm so it's compatible with Xbox, PlayStation, Nintendo, mobile, PC, and more.
SteelSeries Rival 600 - Gaming Mouse - 12,000 CPI TrueMove3+ Dual Optical Sensor - 0.05 Lift-Off Distance - Weight System
$74.99 $79.99 Save $5
SteelSeries Casque Gamer Arctis 7 Noir 2019
$168.19 $258.18 Save $90
The Arctis 1 has high-performance speaker drivers powered by DTS Headphone:X surround sound for crisp, detailed sound and positional audio that is super helpful when playing video games. It can also deliver clear communication from your teammates. With the ClearCast detachable microphone, you'll also be able to communicate to your team. There will be no interference from the game you're playing thanks to the bi-directional design that cancels out background noise.
As a wireless headset, you need something that can last for more than a little while when playing games. The Arctis 1 battery can go for up to 20 hours on a single charge.
Since the headset connects via 2.4GHz wireless, you will get lossless audio and a low-latency connection. Unfortunately, that means it won't work wirelessly with the Xbox. However, it will work with the PlayStation 4, Nintendo Switch, PC, and even Android thanks to the USB-C dongle it comes with. You'll also get a USB-A adapter and a charging cable that lets you go wired if you want.
