Start using Bluetooth in your vehicle with the discounted Roav Receiver for only $12
Amazon has Anker's Roav Bluetooth Receiver available for just $11.89 today when you clip its on-page coupon and enter promo code UPROAV118 during checkout. It sells for as much as $17 and hasn't ever fallen this low in price on its own before. Today's deal marks one of its lowest prices in history, so you won't want to miss this opportunity.
Anker Soundcore Life Q30 hybrid active noise-cancelling Bluetooth headphones
$59.99 $79.99 Save $20
These hybrid Bluetooth headphones reduce ambient noise up to 95% thanks to active noise-cancelling mics. The battery lasts up to 40 hours with ANC on or 60 hours with it off, and recharge via USB-C. Clip the $20 on-page coupon.
Anker Powerline II 6-feet USB-C to Lightning cable
$12.74 $15.00 Save $2
When using a USB-C power adapter (not included), you'll get the fastest possible charge for your iPhone. Plus you can seamlessly sync and charge your Mac. This is Apple MFi certified and lasts 12 times longer than other cables.
Anker Liberty Air 2 Pro true wireless earbuds Best Buy
$79.99 $130.00 Save $50
These earbuds have active noise-cancelling that's customizable with a simple app. You'll get a total of 26 hours of playtime with seven hours from a single charge and the rest from the charging case. Uses USB-C and has wireless charging.
Anker Soundcore Rave Neo portable Bluetooth speaker with LED lights
$84.99 $120.00 Save $35
Includes a rechargeable battery that will last for up to 18 hours and can charge other devices with the USB port. IPX7 rated for water resistance. The built-in LED lights will sync to the music you're playing. Connect multiple speakers together.
Anker Soundcore Liberty 2 Pro true wireless earbuds black
$49.99 $100.00 Save $50
They last for up to eight hours on a single charge with up to 32 hours total using the charging case. They have quick charge so you can get two hours after 10 minutes spent charging. They also charge via USB-C or a Qi wireless charger.
As the owner of a similar Bluetooth receiver, let's just say I won't be going anywhere without it in the future. You simply plug it in via your car's Aux-in port, and there's also a USB cable which will need to be plugged into a USB car charger to power the device. A car charger isn't included with your purchase, so you may want to pick one up with this order.
Inside, the Roav receiver features an advanced CSR chipset to process the wireless signal. It can connect to devices from up to 33 feet away using Bluetooth 4.1 and is even equipped with a built-in microphone with noise-cancellation technology to help eliminate the sound of the road in the background of your calls. Anker provides a one-year warranty with its purchase.
If you don't already own a USB car charger to use with this Bluetooth receiver, you'll want to add one to your cart before checking out. Anker has its PowerDrive 2 USB Car Charger on sale as well for only $7.49. This model features two USB ports so you'll be able to charge your phone even while the Bluetooth receiver is plugged in.
Shipping at Amazon is free on orders totaling $25 or more, or with an Amazon Prime membership. If you've never been a member before, you can start a free 30-day trial of Prime to score free two-day shipping with no order minimum. You'll also gain access to perks such as the Prime Video streaming service, exclusive members-only discounts, and much more.
