Spigen Thin Fit case for Pixel 2 XL review: Basic protection with some flaws
Android Central Verdict
Price: $11.99Bottom line: While this is a great basic case, there are some issues that keep me from universally recommending it.
Pros
    Easy to get the phone in and out
    Doesn't add any real bulk
    Precise cutouts for the camera and fingerprint sensors
    Features a slot for Spigen's magnetic car mounts
Cons
    Doesn't offer much grip or protection
    The front edges are sharp enough to dig into your thighs or hands
    Only one color option
Spigen is known for making plenty of phone accessories, from Style Rings to screen protectors and even headphones. But Spigen is most famous for offering a variety of cases for nearly every phone out there, from ultra rugged cases down to the simpler Thin Fit series. There are lots of great cases for the Pixel 2 XL, but Spigen's Thin Fit may be the right choice for you.
I — Tom Westrick — have been using the Thin Fit case with my Pixel 2 XL since July 3rd. Spigen provided the case for this review.
Feels like I'm wearing nothing at all. Nothing at all. Nothing at all...
Spigen Thin Fit for Pixel 2 XL What I like
I dislike using cases 24/7 because most cases make my phone too bulky. Not so with the Thin Fit: it adds just a hair of thickness meaning my pockets don't feel any more weighed down than normal. The case is a simple piece of black plastic: it snaps onto the phone with ease. If I do need to remove the phone for any reason, that's just as easy.
Since this is such a thin case, there's really nothing blocking the top microphone or the USB-C port. If you have trouble getting some of your charging cables to fit with other cases on, this may be the best choice for you. The case isn't nearly thick enough to interfere with photos and videos taken on the rear camera, and my fingerprint reads just as well as it does when the phone is naked.
While I don't own one of Spigen's magnetic car mounts, this case features a spot for the magnet to stick to. And while I prefer buttons that are replicated on the case itself, the cutouts for the power and volume buttons are generous enough that it doesn't bother me.
A bit too pointy
Spigen Thin Fit for Pixel 2 XL What I Don't Like
My main complaint with this case comes down to the finish of the front of the case: there's an ever-so-slight lip to protect the glass if you place the phone face-down, and — at least on the case I received — this lip is sharp enough for me to notice it digging into my thighs or my hands. It isn't something I've even thought about with other cases, which should tell you how pronounced it is on this sample.
The finish on the case is also a bit too smooth for my liking; I felt like I had less grip on the phone in this case than I did when the phone was uncovered. Finally, while I myself would buy a black case anyway, it'd be great for Spigen to offer more colors for those that want more variety.
Not perfect, but...
Spigen Thin Fit for Pixel 2 XL: Should you buy this?
Maybe. I wouldn't buy it myself, because it doesn't offer enough protection or grip to make it worth using to me. But if you want something that will just protect the back glass of your phone and you don't want to deal with a skin, this isn't a bad option. Just don't hesitate to return the case if it's uncomfortable to hold or put in your pocket.
3 out of 5
If you get a sample with a smoother front edge than I did, this case is easier to recommend.
See at Amazon
