Spigen Thin Fit case for Galaxy S7 edge
If you're in the market for a phone case that allows you to enjoy the natural feel of your Samsung Galaxy S7 Edge and still offers protection, the Spigen Thin Fit case is a great option.
Style
The Thin Fit case is just a simple hard shell that has just enough bend to it to make it easy to snap on and off. It's designed to be pretty minimalist, meaning it doesn't add much bulk to your phone at all. This case won't protect your phone as much as other ones out there, but that's always going to be the trade-off with cases this thin. You can get the Thin Fit case in black, white, and mint.
Features
It has none and that's not a bad thing. It's made for people who like things plain and simple. Since this case is pretty thin, it will still allow you to use wireless charging without a problem, so you don't have to take it off every night.
Design
The Spigen Thin Fit case is designed with functionality in mind. All of the ports and buttons are completely accessible and the edges along the top and bottom are exposed. The case covers the entire back of your phone, so minor scrapes shouldn't be a problem. Also, it does have a raised lip around the rear camera, giving it added protection from falling, as well as a raised lip on the front that protects the screen from scratches if laid face-down. The front lip does not, however, interfere with edge functions at all.
The bottom line
Spigen Thin Fit
The Thin Fit protects the back of your phone entirely, so you don't need to worry about the change in your pocket or the keys in your purse scratching that beautiful coating. None of the key features or functionality of the Galaxy S7 edge are hindered in anyway, and wireless charging doesn't require you to take it off. If you're looking for a case that is simple and doesn't make your Galaxy S7 edge any bulkier, a minimalist case like Spigen's Thin Fit could be perfect for you.
See at Amazon
