Smartphone cases come in many different shapes and sizes. Some cases have built-in screen protectors, some have hidden wallets, and others come with kickstands.
The Spigen Rugged Armor has no such special features. It's about as basic a case as you can find, but if you have a Galaxy S10 and want something that'll protect your phone while being slim, easy-to-use, and affordable, it's one of the best options out there.
Pros
- Offers good protection
- Slim build
- Easy to take on and off
- Buttons have good tactility
- Price is right
Cons
- Back is slippery
- The design is a bit boring
Spigen Rugged Armor for Galaxy S10 What I like
Big, bulky, over-the-top cases have never been my thing, so that's probably why I like the Spigen Rugged Armor as much as I do. It's one of those cases that's easy to put on, gets out of the way, and does its job really well.
Made out of Thermoplastic Polyurethane (TPU), the Rugged Armor case is extremely easy to take on and off of the S10 thanks to its flexible design. Once on the phone, you have solid protection from drops and falls of all kind thanks to Spigen's Air Cushion Technology that absorbs the shock of unexpected impacts. The top and bottom edges of the case are raised ever-so-slightly to also protect the screen. Because of this, you've got full 360° protection.
Thankfully, all of those safety features don't really compromise the day-to-day feel of using the S10. In fact, the case even enhances some aspects of it.
The frame of the Rugged Armor is textured, making it easier to pick the S10 up from a table or get a good grip while holding it. The buttons are also very tactile with a good physical response, and the cutouts for the USB-C port and headphone jack work just like you'd expect.
Out of all this, however, my favorite thing is that the Rugged Armor doesn't add much thickness to the S10. It's certainly not the thinnest case you can buy, but considering the level of protection it offers, it's a pretty compact form factor.
Spigen Rugged Armor for Galaxy S10 What I don't like
With all that praise said, there are a few minor gripes I have with the Rugged Armor.
The back of the case features a very soft rubber finish that proves to be quite slippery at times. There are two sections of a carbon fiber texture at the top and bottom of the back, leaving me to think about the kind of grip we could get if that was extended for the entire backside of the case.
My second complaint is highly subjective, but I wish the Rugged Armor would get a redesign similar to Spigen's Neo Hybrid Galaxy S10 case. Rugged Armor looks fine, but the whole aesthetic gets boring real quick. Even just some additional colors would help with this, but as with past Rugged Armor releases, you can get any color as long as it's black.
Spigen Rugged Armor for Galaxy S10 Should you buy it?
Definitely! Spigen's Rugged Armor is consistently a solid case for just about every major phone that's released, and with the Galaxy S10, it's no different.
4 out of 5
The design is starting to show its age a bit and the soft rubber isn't the grippiest, but the combination of all-around protection, tactile buttons, slim profile, and a great price make it well worth the small amount Spigen's asking.
Joe Maring was a Senior Editor for Android Central between 2017 and 2021. You can reach him on Twitter at @JoeMaring1.
