Treat your ears to a Sonos One speaker at a rare $25 discount
The first Sonos smart speaker with Alexa built in, the Sonos One is currently on sale at B&H for just $144.95, which is $25 off and one of its best prices. This speaker doesn't fluctuate much in price from its $179 regular cost, so when it does you should grab one for another room of your home.
Sonos Play:1 smart speaker refurbished
$99.99 $200.00 Save $100
Only the black speaker is available at this price. Can stream music from your favorite platforms. Syncs with other Sonos speakers, including creating stereo sound when paired with a second Play:1. Also can be controlled from an app on your phone.
Sonos One SL and 2nd-gen One smart speaker
$139.00 $179.00 Save $40
The One SL is down to $139 and the 2nd-gen One is down to $159. Both prices are $40 off what they regularly go for. Both are just $10 above what they were during Black Friday. Sonos deals do not last long so hop on that train. Choo-choo!
Sonos One, One XL, Five smart speakers
As low as $130
Get the Sonos One, Sonos One SL, or even the Sonos Five (at Best Buy) all on sale. Not only do you get brilliant audio, you get a fully connected speaker with Apple AirPlay 2, the Sonos app, and the ability to connect to other Sonos speakers.
Sonos Beam Smart TV sound bar with Alexa black
$299.00 $399.00 Save $100
It's smart, compact, and designed with high-definition audio in mind. Fill your room with great music from your TV, your mobile device, or the radio. Controlled with the remote, the Sonos app, or even the built-in Alexa voice control.
Sonos Move battery-powered Bluetooth smart speaker with Alexa
$299.00 $400.00 Save $101
Get it in Black or White. It's a battery-powered smart speaker that lasts up to 11 hours. Recharges via USB-C or with the included base. Control with Sonos app, Bluetooth, AirPlay 2, or your voice with Alexa. Has IP56 rating for weather resistance.
The Sonos One adds Amazon's Alexa functionality right into the speaker, so you don't need to purchase anything extra to use voice commands to control it. It can also serve as one part of a multi-room speaker setup, whether you buy multiple Sonos One speakers or add on a Play:1, you can connect them all in one of the best home audio setups around.
The second generation model of the Sonos One was just recently released, but Sonos didn't make too much of a stir about it as there aren't too many big changes between the two. Today's deal is for the first model, which is being discounted likely to make room for the next version. All in all, this just makes for a great time to buy.
If you're curious about what all Alexa can do for you, be sure to check out Amazon's Alexa Skills homepage which can unlock a ton of new features and more.
