Snag two Anker PowerWave wireless charging pads for less than $10 apiece
If you don't have a wireless charging pad on your desk, nightstand, end table, kitchen counter, and bathroom sink, then you aren't livin', my friend. All jokes aside, taking advantage of your smartphone's wireless charging capabilities provides a really convenient experience. Add two Anker PowerWave Wireless Charging Pads to your arsenal for under $10 each today when you apply promo code SD192503 during checkout at Amazon. That's $5 off the current cost as well as one of the best deals we've ever shared for these well-rated gadgets. Use Amazon Prime or spend at least $25 to skip the shipping fees.
Anker Soundcore Life Q30 hybrid active noise-cancelling Bluetooth headphones
$59.99 $79.99 Save $20
These hybrid Bluetooth headphones reduce ambient noise up to 95% thanks to active noise-cancelling mics. The battery lasts up to 40 hours with ANC on or 60 hours with it off, and recharge via USB-C. Clip the $20 on-page coupon.
Anker Powerline II 6-feet USB-C to Lightning cable
$12.74 $15.00 Save $2
When using a USB-C power adapter (not included), you'll get the fastest possible charge for your iPhone. Plus you can seamlessly sync and charge your Mac. This is Apple MFi certified and lasts 12 times longer than other cables.
Anker Liberty Air 2 Pro true wireless earbuds Best Buy
$79.99 $130.00 Save $50
These earbuds have active noise-cancelling that's customizable with a simple app. You'll get a total of 26 hours of playtime with seven hours from a single charge and the rest from the charging case. Uses USB-C and has wireless charging.
Anker Soundcore Rave Neo portable Bluetooth speaker with LED lights
$84.99 $120.00 Save $35
Includes a rechargeable battery that will last for up to 18 hours and can charge other devices with the USB port. IPX7 rated for water resistance. The built-in LED lights will sync to the music you're playing. Connect multiple speakers together.
Anker Soundcore Liberty 2 Pro true wireless earbuds black
$49.99 $100.00 Save $50
They last for up to eight hours on a single charge with up to 32 hours total using the charging case. They have quick charge so you can get two hours after 10 minutes spent charging. They also charge via USB-C or a Qi wireless charger.
Most modern smartphones can charge wirelessly, and most new products ship with the capability as well. You can even charge things like second-generation AirPods or Samsung's Galaxy Buds. Basically, wireless charging is a big part of future tech. Get these wireless charging pads at a discount and you'll still be using them a year from now.
These pads provide 10W high-speed charging for Samsung Galaxy and other compatible phones, and they provide a 7.5W fast charge for any iPhone with wireless charging. Other devices that support regular Qi charging will power up at the standard 5W. The LED indicator lets you know the charging status of the device, including whether or not the phone's case is too thick or there's something else between the phone and the charger. Luckily, the pads work with most cases up to 5mm thick. Any metal or cards in the back of the phone will prevent charging. Your purchase comes with an 18-month warranty.
It's worth noting that the charger comes with the necessary cable but does not come with a wall adapter, and you'll want one with Quick Charge 3.0 if you plan to use that tech, so it would be wise to pick at least one up today to ensure you're getting the fastest possible charge.
Be an expert in 5 minutes
Louryn saves money on everything she buys (which is a lot.) In between waiting for Amazon deliveries, she pines for the next Elder Scrolls installment and checks Reddit for gaming rumors. She also loves Hearthstone, makeup, and beer. Find her on Twitter: @lourynstrampe
