Whether you're already all-in on smart home tech or just getting started, you've probably come across Philips Hue products on your shopping trips. The company offers some of the most well-regarded smart lighting devices on the market, though they often come at a significant cost. That's exactly why you need to jump on rare deals on refurbished products when they come around such as this one-day sale on refurb Philips Hue gear at Woot. You can save as much as $20 while smartening up additional areas of your home and rest easy knowing you've got a 90-day warranty in the unlikely event anything goes awry.
Philips SmartSleep wake-up light
$79.95 $100.00 Save $20
Simulates the sunset and sunrise and includes 5 different wake-up sounds. Has an FM radio with snooze and automatic dimmable display. It also includes 10 brightness settings. Help establish a healthy sleeping and waking routine.
Philips Hue white & color BR30 starter kit
$69.99 $120.00 Save $50
The kit includes two multicolor BR30 smart bulbs and the Philips Hue bridge designed to help you unite your bulbs and connect them to your Wi-Fi network. Find the perfect lighting with preset scenes or lighting effects that sync to your movie.
Philips Audio Fidelio X2HR over-ear open-air headphones
Up to 20% off
The X2HR have Hi-Res Audio with 50mm high-def neodymium drivers and an acoustic open-back architecture. They have deluxe memory foam ear pads and a lightweight adjustable hammock with genuine leather.
Philips SmartSleep Connected sleep and wake-up light therapy lamp
$169.99 $200.00 Save $30
Built-in bedroom sensor and smartphone connection helps create ideal environment. AmbiTrack sensor measures your bedroom's temp, noise, light, and humidity. Customize the alarm, light, sound, and sunrise/sunset themes. Has clock and touch display.
Philips goLITE BLU Rechargeable Energy Light
$130.40 $137.79 Save $7
For those new to Hue, the sale features a White A19 2nd Gen 2-Bulb Starter Kit at $44.99. It comes with two warm white smart LED bulbs as well as the necessary hub to get them set up (and add more lights later). Once up and running, you can control the lights remotely, set timers and light schedules, and automate your lights to make it seem like someone is home even when you are away. If you have a smart speaker like the Echo Dot, you can use just your voice to adjust your lighting too. This kit is usually nearer $70 if purchased brand new.
If you're already using Hue elsewhere, you can still use this refurb sale to add some ambience to another area of your home with a discounted Philips Hue LightStrip Plus also down to $44.99. It usually goes for at least $65 at Amazon. It requires that you already have a Philips Hue hub set up and can show millions of colors and shades of white light. You can also sync it with games, music and movies for enhanced experiences. The 80-inch is strip easy to install under your TV stand or kitchen counter with its adhesive and has all of the same automation and remote control smarts as the regular bulbs.
Shipping is free at Woot if you log in using your Amazon Prime account, otherwise it's an additional $6 fee.
