SwitchBot Lock promises to easily upgrade your deadbolt to a smart lock
The new Lock takes less than a minute to convert your deadbolt locks to smart locks.
- SwitchBot Lock converts your old locks to smart ones without needing to be refitted.
- Users can lock/unlock their doors right from their smartphones or Apple smartwatches.
- There are several ways of locking and unlocking, including support for voice assistants.
- SwitchBot claims its new lock will install in less than a minute.
The SwitchBot Lock is a simple approach to upgrading your existing door locks. It promises to convert your old locking system without a need for refitting. This new intelligent home locking system is powered by Bluetooth and can help users lock, control, or open the lock through a smartphone or an Apple Watch. The company assures the smart lock is compatible with most deadbolt locks and further promises to provide 3D-printed accessories for compatibility.
The emphasis of this new system is its ability to transform your dumb locks into smart ones by using a 3M VHB tape to stick to the door. SwitchBot promises the initial setup will take less than a minute.
The smart door lock includes different-sized thumb-turn adapters to lock and unlock your door. SwitchBot suggests that this approach has undergone nearly 50,000 locking/unlocking tests — equivalent to five-year usage, considering the use of an average consumer.
The locking system on the new Lock comes with a handy automated lock feature, which makes it lock automatically as you head out. You can also use the SwitchBot Lock app on Android phones, iPhones, or Apple smartwatches. It even provides widgets for both iOS and Android platforms, giving users easy access to their doors. If you spring for a SwitchBot Hub Mini/Plus, you can add support for voice assistants like Alexa and Google Assistant.
Apart from the aforementioned unlocking techniques, there are several other ways to interact with SwitchBot Lock. The SwitchBot Keypad (sold separately) lets you enter a passcode, while the SwitchBot Keypad Touch even lets you use your fingerprint. The Keypads also allow users to create and share a temporary password, which can be helpful if you often deal with housekeepers or renters. Both keypads are coming later this year.
You can also use an NFC tag to quickly unlock with compatible smartphones.
Lastly, SwitchBot assures a six-month battery life on this new Lock, which translates to locking and unlocking at least ten times a day on an average. The company additionally ensures that the SwitchBot Lock features a bank-security level of data encryption to keep you safe, and it has other nifty security features like getting notified on your phone when the door is opened or locked.
Be an expert in 5 minutes
The SwitchBot comes in a black colorway and retails at $99.99, making it among the more affordable smart locks. It can be purchased through the SwitchBot online store or Amazon.
The SwitchBot Lock is the easiest way to convert your dumb lock into a smart one. Just stick it on your door and go, using a keypad, NFC tag, or SwitchBot app to lock or unlock your door.
Vishnu is a freelance news writer for Android Central. Since 2018, he has written about consumer technology, especially smartphones, computers, and every other gizmo connected to the internet. When he is not at the keyboard, you can find him on a long drive or lounging on the couch binge-watching a crime series.
