The sleek Soundcore Liberty 2 Pro True Wireless Earbuds are on sale for $130
Soundcore Liberty 2 Pro (Image credit: Daniel Bader / Android Central)
The AirPods Pro are great, but you don't have to spend anywhere near $250 to score a worthwhile pair of in-ear true wireless earbuds. Anker's Soundcore Liberty 2 Pro come in at $100 less than their Apple competition on any given day, and they've even been recommended by multiple Grammy Award-winning producers for their in-studio performance. Thanks to a current sale at Best Buy, you can snag a pair today for only $129.99. That saves you $20 off their usual cost of $149.99 and brings these headphones back to one of the lowest prices they've ever reached.
Anker Soundcore Life Q30 hybrid active noise-cancelling Bluetooth headphones
$59.99 $79.99 Save $20
These hybrid Bluetooth headphones reduce ambient noise up to 95% thanks to active noise-cancelling mics. The battery lasts up to 40 hours with ANC on or 60 hours with it off, and recharge via USB-C. Clip the $20 on-page coupon.
Anker Powerline II 6-feet USB-C to Lightning cable
$12.74 $15.00 Save $2
When using a USB-C power adapter (not included), you'll get the fastest possible charge for your iPhone. Plus you can seamlessly sync and charge your Mac. This is Apple MFi certified and lasts 12 times longer than other cables.
Anker Liberty Air 2 Pro true wireless earbuds Best Buy
$79.99 $130.00 Save $50
These earbuds have active noise-cancelling that's customizable with a simple app. You'll get a total of 26 hours of playtime with seven hours from a single charge and the rest from the charging case. Uses USB-C and has wireless charging.
Anker Soundcore Rave Neo portable Bluetooth speaker with LED lights
$84.99 $120.00 Save $35
Includes a rechargeable battery that will last for up to 18 hours and can charge other devices with the USB port. IPX7 rated for water resistance. The built-in LED lights will sync to the music you're playing. Connect multiple speakers together.
Anker Soundcore Liberty 2 Pro true wireless earbuds black
$49.99 $100.00 Save $50
They last for up to eight hours on a single charge with up to 32 hours total using the charging case. They have quick charge so you can get two hours after 10 minutes spent charging. They also charge via USB-C or a Qi wireless charger.
The Soundcore Liberty 2 Pro true wireless earbuds feature a state-of-the-art design which integrates a customized Knowles balanced armature and an 11mm dynamic driver for enhanced audio you'll have to hear to believe. The result of all of Anker's finetuning is an expansive soundstage that lets you hear every instrument and every nuance of the music you're listening to. There are also four built-in microphones with cVc 8.0 noise reduction so you can take calls hands-free and be heard clearly.
With an 8-hour battery life, you'll be able to get a good listening session out of these earbuds for the most part. Just like AirPods, these earbuds come with a charging case that doubles as a protective carrying case to keep them in when they're not in use. Storing them in the case can recharge them fully twice while you're on-the-go for a total of 24 hours of listening time; that matches how long Apple says the AirPods Pro should last with their charging case. Plus, the Liberty 2 Pro are able to be wirelessly charged too. You'll just need a wireless charging pad at home. Another feature similar to the AirPods Pro is the Liberty 2 Pro's HearID technology which analyzes your hearing profile and creates a tailor-made sound just for your ears.
For more information on the Liberty 2 Pro earbuds, be sure to check out our review which rated them with 4.5 out of 5 stars.
