If none of the deals over Black Friday weekend convinced you to pull the trigger on a robot vacuum cleaner, perhaps this one will. Amazon has the popular ILIFE V3 Pro Robotic Vacuum on sale for just $118.99. It normally sells for $160 and today's discount is the best price it has seen in over six months. If you missed the one-day sale on it back in February when it went to $7 lower, this is likely your best chance to get it at a discount for a while.
iLife Shinebot W400s mopping robot
$172.49 $230.00 Save $58
Mops in four stages: sprays your hard floor with clean water, scrubs with a microfiber roller, removes the dirty water, then wipes off any residues with a rubber scraper. Has multiple cleaning modes and can clean up to 600 square feet.
$159.99 $229.99 Save $70
This smart robot vacuum cleaner automatically maps and navigates your home to keep it clean. Control it with the free app or even with your voice and a smart home assistant like Alexa or Google Assistant. Clip the on-page coupon to save.
ILIFE V8s Robot Vacuum Cleaner
$169.99 $249.99 Save $80
$149.99 $179.99 Save $30
$179.99 $299.99 Save $120
This model is designed to work best on hard floors, though it can go over low pile carpet as well. Its pet hair care technology helps it focus on getting all the dirt, debris, and hair that your pets leave behind. It has a low profile design to help it get under couches with ease, and the smart sensors will prevent it from bumping into everything or falling down stairs. When the battery gets low, it will return to the charger, and you can program a set schedule for it to clean. With over 2,700 reviews, the V3s Pro maintains an impressive 4.1 out of 5-star rating.
We named the ILIFE V3s Pro as our best budget pick on our list of the best robot vacuums in 2019, though that list is chock-full of options to suit all budgets if you want to take a peek. It's unlikely you'll be able to snag a deal quite as good as today's, but you might find something that is more suitable feature-wise for your needs.
Be an expert in 5 minutes
