Seneo's $6 wireless charging stand can power your phone faster than most cables
More likely than not, you already have a phone that is compatible with wireless charging. The latest iPhone models, Samsung Galaxy devices, and tons of other phones are already capable of powering up wirelessly, and it's not very expensive to pick up a wireless charger, either. Right now you can snag Seneo's 7.5W Fast Wireless Charging Stand at Amazon for only $5.99 when you enter promo code WSOSSF5O during checkout, and at that price, you might even want to pick up more than one in this order.
This product was designed as a 2-in-1 device that works as both a wireless charging pad and a wireless charging stand, letting you use it as you'd like. It's compatible with all Qi-enabled devices and charges the latest Samsung Galaxy phones at up to 10W, while the recent iPhone models charge at 7.5W. All other Qi-enabled devices charge at 5W.
There's even an integrated silicone ring that helps ensure your phone never slides off the pad while charging. Plus, Seneo backs up this wireless charger with a three-year warranty in case you experience any issues with it.
No AC adapter is included with this charger, so if you don't already have one at home that can be used to power it up, you'll want to add one to your order before checking out.
Alternatively, Seneo's 10W Wireless Charging Pad is on sale for as low as $8.69 when you enter code RRUNH8OQ during checkout as an Amazon Prime member.
