Secure an incredible 56% off the Arlo Pro 2 with three cameras, now only $300
Arlo Pro 2
Arlo Pro 2 (Image credit: Arlo)
The Arlo Pro 2 Wireless Home Security Camera System is one of the most convenient home security systems around, and right now, there's an incredible saving to be had of over 56% on Amazon, where $300 will net you a base unit and three cameras!
The sale features Arlo's Pro, Pro 2, and Ultra camera kits so you can get equipped with whichever suits your needs and budget. There's also a high-tech baby monitor on sale. The prices represent new lows, so you're getting a bargain no matter what.
Arlo Pro 2 1-cam wireless security system
$99.99 $120.00 Save $20
With this package you get one wireless security camera with a rechargeable battery and the base station that helps you manage your system even as you add more cameras. They record 1080p video on a 130-degree angle lens.
Arlo Pro 4 3-pack wireless security 2K spotlight cameras
$449.99 $550.00 Save $100
Two-way audio lets you speak to visitors and respond quickly to notifications. The camera has a 160-degree viewing angle with an integrated spotlight. With no wires, set up is a breeze. Siren can turn away unwanted guests. Works with smart homes.
Arlo AVD1001 Video Doorbell
Records video in 1080p with detailed HDR for better image quality. Has a 180-degree viewing angle so you can see everything in front of the door. Includes two-way audio, motion detection, smart alerts, a built-in siren, and even package detection.
Arlo Essential Spotlight wire-free camera
$79.00 $130.00 Save $51
Part of Home Depot's Cyber Savings event, which ends tonight. Wireless camera. Records in 1080p video. Includes color night vision, two-way audio, a battery that lasts six months, and motion detection. Doesn't need a hub. Works with Alexa.
Arlo Q 1080p HD Wi-Fi security camera
$79.99 $110.00 Save $30
Always see last 7 days with free cloud storage. This camera records in 1080p video that can be viewed from any mobile device. It also has motion and sound detection, two-way audio, and night vision. Works with Alexa, Google, HomeKit, and more.
Arlo Pro 2's system is 100% wireless and weather resistant. It records in 1080p and has 24/7 recording with a local storage option. Each camera has a 130-degree field of view. It's one of the best plug and play systems out there, and one of the only previous drawbacks was its steep price tag. Now its less than half price this really is a no brainer.
Not only that, Arlo is having a sale across its Amazon range right now, you can pick up the original Arlo Pro with one camera for just $130! There's also a baby monitor, and deals on Arlo Ultra, which gives you home security in 4K UHD for just $336.
This is a limited time deal and will be sure to sell out fast, so check it out now!
Also, be sure to check out the rest of our Black Friday deals at our Black Friday hub.
