Seagate's FireCuda 2TB hybrid drive combines storage and speed for just $65
The Seagate FireCuda 2TB internal drive is not a solid state drive, but it's also not a hard drive. It's a hybrid drive, which is somewhere in between. It has the storage of a 2TB hard drive but it uses NAND memory and a cache system to allow for performance closer to an SSD. This drive sells regularly for around $90. Today's discount is a match for the lowest price we've ever seen, and this is a price it has only hit once or twice in the last year.
Seagate Expansion 14TB USB 3.0 external desktop hard drive black
$199.99 $250.00 Save $50
I mean, 14TB is a whole lot of space to work with. Works with Windows PCs and connects easily via USB. It's plug-and-play so you don't need any extra software. Comes with an 18-inch USB cable and 18W power adapter. It is covered by a 1-year warranty.
Seagate Backup Plus Slim 1TB portable hard drive Space Gray
$44.99 $60.00 Save $15
This USB 3.0 drive that's backwards compatible with USB 2.0 and works seamlessly between Windows and Mac without reformatting. Has customized backups and folder mirroring. Comes with a year of Mylio Create and 2 months of Adobe Photography Plan.
Seagate Ultra Touch 500GB USB-C portable solid state drive
$74.99 $85.00 Save $10
Designed to be Android Ready so you can easily manage your phone using the included Android app. Has universal compatibility thanks to the USB-C port so it works on Windows and Mac. Lightweight design with fabric cover. Includes 3-year warranty.
Seagate Expansion 10TB external USB 3.0 hard drive
$169.99 $190.00 Save $20
Uses USB 3.0 for connection and fast data transfer speeds. Backwards compatible with USB 2.0. Plug in the power adapter and USB cable and it's good to go. Just drag and drop right out of the box. Works with Windows. Comes with 1-year warranty.
Seagate One Touch 4TB external hard drive
$89.99 $105.00 Save $15
A simple on-the-go USB drive with a minimalist brushed metal enclosure. Works great as a backup or for portable media storage. Comes with a two-year warranty from Seagate. Compatible with Windows and Mac but may need reformatting for Time Machine.
The single terabyte version goes for $59.99 regularly, so you're only paying about $15 to double the space. However, if you don't quite need all that space you can get the 500GB version on sale for $39.99. That's $15 off its regular price and a new low for the smaller version of this drive.
The process is mostly automatic with the FireCuda (some SSHDs let you manually choose what to do with it). You get a 7200 RPM hard drive, which is already nice and fast for a hard drive. And then you get the cache system that gives you SSD-like performance for some stuff. This sort of drive is perfect if you have very limited storage options, like a laptop that only has one drive bay and is still using an ancient hard drive. The drive also won't add to your power consumption, so you don't have to worry about that.
It comes with a five-year warranty from Seagate and users give it 4.3 out of 5 stars based on 271 reviews.
