Set Seagate's 4TB Expansion External Hard Drive on your desk at its lowest price yet
If you're starting to bump up against the storage limit on your computer, it might be time to think about grabbing another hard drive to help you store all your important files. Seagate's Expansion Desktop 4TB External Hard Drive is a fantastic pick that's now more affordable than ever. On sale at Amazon for just $69.99, this deal saves you $20 off its average cost. Within the last year, it's sold for as much as $100 on a consistent basis.
Seagate Expansion 14TB USB 3.0 external desktop hard drive black
$199.99 $250.00 Save $50
I mean, 14TB is a whole lot of space to work with. Works with Windows PCs and connects easily via USB. It's plug-and-play so you don't need any extra software. Comes with an 18-inch USB cable and 18W power adapter. It is covered by a 1-year warranty.
Seagate Backup Plus Slim 1TB portable hard drive Space Gray
$44.99 $60.00 Save $15
This USB 3.0 drive that's backwards compatible with USB 2.0 and works seamlessly between Windows and Mac without reformatting. Has customized backups and folder mirroring. Comes with a year of Mylio Create and 2 months of Adobe Photography Plan.
Seagate Ultra Touch 500GB USB-C portable solid state drive
$74.99 $85.00 Save $10
Designed to be Android Ready so you can easily manage your phone using the included Android app. Has universal compatibility thanks to the USB-C port so it works on Windows and Mac. Lightweight design with fabric cover. Includes 3-year warranty.
Seagate Expansion 10TB external USB 3.0 hard drive
$169.99 $190.00 Save $20
Uses USB 3.0 for connection and fast data transfer speeds. Backwards compatible with USB 2.0. Plug in the power adapter and USB cable and it's good to go. Just drag and drop right out of the box. Works with Windows. Comes with 1-year warranty.
Seagate One Touch 4TB external hard drive
$89.99 $105.00 Save $15
A simple on-the-go USB drive with a minimalist brushed metal enclosure. Works great as a backup or for portable media storage. Comes with a two-year warranty from Seagate. Compatible with Windows and Mac but may need reformatting for Time Machine.
Seagate's Expansion 4TB hard drive is compatible with both Windows and Mac computers but would first need to be reformatted for use on Mac. If you're a Windows user though, you'll be able to get started with saving files and folders directly to the hard drive right out of the box without having to install anything. This hard drive does require to be plugged in via a power adapter and also a USB cable and features SuperSpeed USB 3.0 for quick file transfers. Existing owners give it 4 out of 5 stars based on over 4,000 Amazon reviews.
