The Seagate Expansion 8TB external hard drive has dropped to just $120
The Seagate Expansion 8TB USB 3.0 external desktop hard drive is on sale for $119.99 through Newegg's eBay storefront. This discount comes as a result of a general sale on the 8TB drive that has dropped it down to $125 on Newegg's main site, Amazon, and other places. It would normally cost you $140 or more, and the eBay deal is the best price we've seen.
Seagate Expansion 14TB USB 3.0 external desktop hard drive black
$199.99 $250.00 Save $50
I mean, 14TB is a whole lot of space to work with. Works with Windows PCs and connects easily via USB. It's plug-and-play so you don't need any extra software. Comes with an 18-inch USB cable and 18W power adapter. It is covered by a 1-year warranty.
Seagate Backup Plus Slim 1TB portable hard drive Space Gray
$44.99 $60.00 Save $15
This USB 3.0 drive that's backwards compatible with USB 2.0 and works seamlessly between Windows and Mac without reformatting. Has customized backups and folder mirroring. Comes with a year of Mylio Create and 2 months of Adobe Photography Plan.
Seagate Ultra Touch 500GB USB-C portable solid state drive
$74.99 $85.00 Save $10
Designed to be Android Ready so you can easily manage your phone using the included Android app. Has universal compatibility thanks to the USB-C port so it works on Windows and Mac. Lightweight design with fabric cover. Includes 3-year warranty.
Seagate Expansion 10TB external USB 3.0 hard drive
$169.99 $190.00 Save $20
Uses USB 3.0 for connection and fast data transfer speeds. Backwards compatible with USB 2.0. Plug in the power adapter and USB cable and it's good to go. Just drag and drop right out of the box. Works with Windows. Comes with 1-year warranty.
Seagate One Touch 4TB external hard drive
$89.99 $105.00 Save $15
A simple on-the-go USB drive with a minimalist brushed metal enclosure. Works great as a backup or for portable media storage. Comes with a two-year warranty from Seagate. Compatible with Windows and Mac but may need reformatting for Time Machine.
The Seagate Expansion 8TB is huge! That's so much space. Don't worry about having to put it inside your computer, either, because it will sit right on your desktop. It has storage that will last you for years. You can keep all your big files on it, and you don't have to worry about adding more. Fill it up with movies, photos, music, and anything else you can think of.
The drive is plug-and-play, too. Just connect it to your Windows computer and it will automatically work. The system should recognize it and get it working for you. You won't need to install any software or drivers. And once it's up and working you can transfer your files with simple drag and drop.
It comes with an 18-inch USB 3.0 cable and an 18W power adapter. Seagate also backs it up with a one-year warranty. This hard drive has more than 10,000 user reviews on Amazon with 4.1 stars out of 5.
