Upgrade your hard drive with the 2TB Seagate BarraCuda on sale for $50
The Seagate BarraCuda 2TB 7200 RPM internal hard drive is down to $49.99 on Amazon. This drive was selling as high as $68 in July, but more regularly sells for around $55. The drop to $50 is a match for its lowest ever. This deal even matches the price of the previous generation, despite being a more updated and faster drive.
Seagate Expansion 14TB USB 3.0 external desktop hard drive black
$199.99 $250.00 Save $50
I mean, 14TB is a whole lot of space to work with. Works with Windows PCs and connects easily via USB. It's plug-and-play so you don't need any extra software. Comes with an 18-inch USB cable and 18W power adapter. It is covered by a 1-year warranty.
Seagate Backup Plus Slim 1TB portable hard drive Space Gray
$44.99 $60.00 Save $15
This USB 3.0 drive that's backwards compatible with USB 2.0 and works seamlessly between Windows and Mac without reformatting. Has customized backups and folder mirroring. Comes with a year of Mylio Create and 2 months of Adobe Photography Plan.
Seagate Ultra Touch 500GB USB-C portable solid state drive
$74.99 $85.00 Save $10
Designed to be Android Ready so you can easily manage your phone using the included Android app. Has universal compatibility thanks to the USB-C port so it works on Windows and Mac. Lightweight design with fabric cover. Includes 3-year warranty.
Seagate Expansion 10TB external USB 3.0 hard drive
$169.99 $190.00 Save $20
Uses USB 3.0 for connection and fast data transfer speeds. Backwards compatible with USB 2.0. Plug in the power adapter and USB cable and it's good to go. Just drag and drop right out of the box. Works with Windows. Comes with 1-year warranty.
Seagate One Touch 4TB external hard drive
$89.99 $105.00 Save $15
A simple on-the-go USB drive with a minimalist brushed metal enclosure. Works great as a backup or for portable media storage. Comes with a two-year warranty from Seagate. Compatible with Windows and Mac but may need reformatting for Time Machine.
The BarraCuda is designed to be as cost-effective as possible, which is why the price is so low for so much space. It's still as fast as a SATA connection allows for and spins at 7200 rpm. It comes with Instant Secure Erase software so you can safely retire your old drives if this one is replacing them. There are other security features that allow you to encrypt your data as well.
