Scuf H1 headset review: Scuf's first gaming headphones were worth the wait
Scuf Headset Hero
(Image: © Android Central)
Android Central Verdict
Bottom line: This headset looks as good as it sounds, providing high quality audio with memory foam earpads that will keep you comfortable during long play sessions.
Pros
    Extremely comfortable earpads
    Speaker tags can be easily swapped to customize the look
    Detachable microphone
    In-line volume control
Cons
    Microphone quality isn't as good as audio
Scuf is best known for making excellent controllers like the Scuf Impact and Scuf Vantage 2 for PS4, but last year the company decided to get into the headset game with the launch of the Scuf H1. Corsair, which has a long history of making gaming headsets, bough Scuf in 2019 and the design of the H1 is based on the Corsair Virtuoso.
The wired headset comes in a wide variety of styles meant to perfectly compliment the brand's controllers, but it can be plugged into any 3.5mm jack whether on your PS5, Xbox Series X, or PC. Regardless of what you're playing, the Scuf H1 wired headset is an impressive first entry into the category, providing a solid mix of style, comfort, and excellent audio quality. It's also easy to customize with a few add-ons.
Scuf H1 Wired Gaming Headset What I like
Scuf Magnet Covers
Source: Android Central (Image credit: Source: Android Central)
Swipe to scroll horizontally
CategorySpec
Weight800g
Driver diameter50mm
Cable3.5mm
Microphone patternOmnidirectional or Unidirectional
Battery lifeN/A (Wired)
I'm used to using a Sennheiser HMD 280 Pro headset for gaming and podcast recording, but I find the Scuf H1 to be much more comfortable despite being significantly cheaper. I've got a pretty small head and the adjustable synthetic leather headband hugs it neatly with foam against the crown of my head keeping it comfortable without any pinching. The same goes for my ears, which are neatly cupped by the memory foam pads. They're breathable and feel light so I don't get the feeling of fatigue that I sometimes get from long sessions wearing my Sennheiser.
The audio quality is top-notch, with the 50mm high-density neodymium speaker drivers providing phenomenal detail whether its the low-latency cues needed to pick up on an enemy powering up for a special move or just enjoying every note of a beautiful soundtrack. An in-line volume control lets you tune down the noise on the fly if you need to and can also be used to mute your mic if you're grabbing a snack or are trying to save your party from listening to your dog bark.
The headphones are also extremely stylish. I've got the white model with cheerful cherry blossom speaker tags along with plain white hexagonal patterns I could swap on if I was feeling more subdued. The headset also offers a black base and a huge assortment of designs and patterns in a variety of color schemes that can be easily swapped in and out thanks to the built-in magnets.
Scuf H1 Wired Gaming Headset What I don't like
Scuf Headset Plugged In
The headset's microphone is detachable, which is convenient for if you're just playing or listening to music by yourself and don't want it getting in the way of your eating and drinking. However, that convenience comes with a bit of a drop in quality. The Scuf H1 is never going to replace a professional headset if you're serious about recording.
While the 3.5mm jack and fairly long detachable cord make the headset easy to use with just about anything, if you really want the full freedom to move when you play, you should get a headset with a wireless option. Wired provides lower latency so you don't miss key audio cues, but most wireless devices have a wired mode so you have more flexibility in your use.
Scuf H1 Wired Gaming Headset The competition
razer kraken x headset
If you have more money to spend, you might want to go for the Astro A40 + MixAmp Pro headset. It has all the customizability of the Scuf H1 with a swapable microphone and speaker tags while also lettting you easily trade out the ear cushions and headband cushion as needed. However, the Scuf H1 actually has a larger driver diameter, so you're likely to get a bit better sound quality even for the lower price.
If you're on a budget but still want a comfortable 3.5mm headset, you can opt for the Razer Kraken X. It's lightweight and also nicely fits smaller heads. While it's microphone is high quality, it doesn't retract. The volume is also a little harder to adjust on the device.
Scuf H1 Wired Gaming Headset Should you buy it?
Scuf With Controller Hero
Source: Scuf (Image credit: Source: Scuf)
You should buy this if ...
  • You like to customize your accessories to suit your style
  • You want to be comfortable during long gaming sessions
  • You value high quality audio with low latency
You should not buy this if ...
  • You need to record professional level audio
  • You want a wireless headset
  • You're not willing to shell out a bit more for a specific look
4.5 out of 5
Scuf's partnership with Corsair has produced a really impressive new entry to the gaming headset scene. The Scuf H1 is extremely comfortable and looks great. If you want to travel with it or use it during meetings when you're not eager to show off your gamer status with RGB lighting or a similarly loud look, the detachable speaker tags offer a great way to swap your style.
The microphone might not be the best in the market, but it's solid and detaches if you don't want it getting in the way when you're just using audio. The sound is also excellent, meeting or beating the quality of much more expensive devices.
Samantha Nelson
Latest in Accessories
TerraMaster F8 SSD Plus internals next to external casing
The best all-flash Plex NAS finally gets a great discount — act now!
Tagry X08 earbuds in-hand
These are the best-sounding budget earbuds I've ever used, and they're just $25 right now
Google Pixel Buds Pro 2 Wintergreen earbud
Google reveals Pixel Buds Pro 2 cleaning tips that can 'greatly affect' sound
AirPods Max (left) hanging from a park bench beside Beats Studio Pro (right).
USB-C AirPods Max are getting an upgrade Android headphones had all along
UGREEN x Genshin Impact collection
UGREEN sent me the ultimate Genshin Impact accessory package
The Porcelain Google Pixel 9a sitting upright on a mossy surface leaning against a plant.
How fast is the Google Pixel 9a charging speed?
Latest in Review
Kobo Libra Colour review
Kobo Libra Colour review: The obvious upgrade to the Kindle Oasis
Honor MagicPad 2 review
Honor MagicPad 2 review: This mid-range tablet has a unique OLED advantage
Apple iPhone 16e review against colorful background
Apple iPhone 16e review: Elevated basics
Soundcore Liberty 4 Pro showing smart screen Ambient Sound menu
Soundcore Liberty 4 Pro review: Great budget earbuds with some fun tricks!
A OnePlus Watch 3 with a blue watchface
OnePlus Watch 3 review: The best battery life, but not a great fit for everyone
Comparing the transparent backs of the grey Nothing Phone (3a) Pro with the white Nothing Phone (3a)
Nothing Phone 3a and 3a Pro review: Nothing is Essential
