Score two nylon-braided USB-C fast charging cables for only $7 right now
When it's time to replace your charging cables, spending just a little bit extra can make a huge difference in how your device charges. Anker's Premium Nylon USB-C to USB-A Fast Charging Cables are designed to be compatible with Quick Charge-enabled chargers, and they tend to put any charging cable that you recieve with a new device to shame, too. Now that a two-pack of these six-foot long cables are on sale at Amazon for only $6.99 when you enter promo code AKMCM733 during checkout, there's really no excuse not to upgrade today. The pair is regularly sold for up to $11; only the black cables are on sale currently.
Anker Soundcore Life Q30 hybrid active noise-cancelling Bluetooth headphones
$59.99 $79.99 Save $20
These hybrid Bluetooth headphones reduce ambient noise up to 95% thanks to active noise-cancelling mics. The battery lasts up to 40 hours with ANC on or 60 hours with it off, and recharge via USB-C. Clip the $20 on-page coupon.
Anker Powerline II 6-feet USB-C to Lightning cable
$12.74 $15.00 Save $2
When using a USB-C power adapter (not included), you'll get the fastest possible charge for your iPhone. Plus you can seamlessly sync and charge your Mac. This is Apple MFi certified and lasts 12 times longer than other cables.
Anker Liberty Air 2 Pro true wireless earbuds Best Buy
$79.99 $130.00 Save $50
These earbuds have active noise-cancelling that's customizable with a simple app. You'll get a total of 26 hours of playtime with seven hours from a single charge and the rest from the charging case. Uses USB-C and has wireless charging.
Anker Soundcore Rave Neo portable Bluetooth speaker with LED lights
$84.99 $120.00 Save $35
Includes a rechargeable battery that will last for up to 18 hours and can charge other devices with the USB port. IPX7 rated for water resistance. The built-in LED lights will sync to the music you're playing. Connect multiple speakers together.
Anker Soundcore Liberty 2 Pro true wireless earbuds black
$49.99 $100.00 Save $50
They last for up to eight hours on a single charge with up to 32 hours total using the charging case. They have quick charge so you can get two hours after 10 minutes spent charging. They also charge via USB-C or a Qi wireless charger.
Anker designed these cables not just with speed in mind, but durability too. Their premium nylon-braided construction helps these cables last five times longer than standard options. They're universally compatible with any device that has a USB-C port, and with Quick Charge compatibility, you'll be able to get the fastest speeds possible using a Quick Charge USB wall charger or a similar accessory.
You'd also be wise to keep one in your backpack or vehicle so you're always prepared to charge on-the-go. This guide to the best power banks under $30 might come in handy too in that regard. There's also a guide on best portable high-capacity power banks that is worth a glance.
These cables even come with a lifetime warranty, and it's easy to take Anker up on its offer for a replacement if one of them does happen to stop working properly.
Shipping at Amazon is free on orders totaling $25 or more, or with an Amazon Prime membership. If you've never been a Prime member before, consider starting a free 30-day trial today. You'd score free two-day shipping with no order minimum, exclusive members-only discounts, access to the Prime Video streaming service, and more.
Be an expert in 5 minutes
