Score a free Fire TV Stick with Blink XT Smart Security Camera kits today only
Keeping your home safe is easier than ever these days with smart home technology like the Blink XT2 Smart Security Cameras. They're designed to be used indoors or outside and allow you to watch their live video feed from anywhere in the world using an app on your smartphone or tablet, or even on your TV. Today only, Blink XT2 starter kits come with a free Fire TV Stick making it super easy to keep tabs on your home without breaking the bank.
From $28
Amazon is offering a bunch of deals on Blink cameras right now including the first major price drops on the all-new Blink Indoor cams. Prices start at just $28 for the Blink Mini and you can save up to 29% on bundles.
All-new Blink Outdoor HD security camera kits
As low as $65
Built for the outdoors. They are completely wireless with a battery that can last for up to two years. They also have IP67 weather resistance to survive the elements. Other features include motion detection, two-way audio, and phone alerts.
From $75
These cameras use AA batteries that are designed to last for up to two years. They can be used inside or outside too. The one-camera kit is $75 or go for the biggest 5-camera kit for $285. Just $10 more gets you an Echo Show 5, too.
Blink XT2 Smart Security Cameras + Echo Dot
From $75
These operate on AA batteries that are designed to last for up to two years so you can install them just about anywhere. They can be used inside or outside so take your pick. All the kits are 25% off and get you an Echo Dot at no extra cost.
Bink XT2 all-new outdoor indoor home security cameras 1-camera kit
$74.99 $100.00 Save $25
Get two years of life on a set of AA batteries, two-way audio, live view, motion recording, and free cloud storage. These cameras work with Alexa so you can see motion clips, view the feeds live, and more. Records 1080p video with night vision.
The deal applies to all of the starter kits, from the $99.99 1-camera kit all the way up to the 5-camera kit. Buying a starter set will score you the number of cameras you require as well as a Blink Sync Module that acts as the central hub. You could always go for a smaller kit for now and pick up additional add-on cameras down the line if you want to cover more areas of your home.
Building upon the features of original, well-received Blink XT camera. the Blink XT2 offers extended battery life that will keep it powered for two years on just two AA batteries. And just like the original model, it's designed to be 100% wire-free and weatherproof so you can use it anywhere you'd like — whether that be indoors or outdoors. The Blink XT2 records in 1080p HD and features two-way audio, giving you the ability to talk with anyone on the other side of the camera using the Blink Home Monitor app on your phone. That could mean chatting with your family or even reminding your dog to stay out of the garbage.
The XT2 also offers enhanced motion detection which is customizable to help reduce false alerts, as well as compatibility with Amazon Alexa. The neat part about the free Fire TV Stick, worth $40, is the ability to use its included Alexa Voice Remote to get a quick look at whatever your cameras are seeing just by asking. You don't need an additional Echo device to achieve this either, though if you have an Echo device with a screen like the Amazon Echo Show you can also view your camera footage on there.
Unlike many other smart security cameras, the Blink XT2 requires no monthly fees and even offers free cloud storage for clips for a year. Considering that most other camera makers usually only let you store your clips for 30 days without paying, that's a huge deal that could save you a ton of money going forward. You can learn more in our review from last November.
