Score 40% off the well-reviewed Utaxo Noise Cancelling Bluetooth Headphones via Amazon
If all the noise around you keeps you from enjoying movies and music you're listening to, it's time to treat yourself to a pair of noise-cancelling headphones. Of course, the first thing that comes to mind is some expensive pair that costs a few hundred dollars, but you don't have to spend anywhere near that to actually score a set worth picking up. The Utaxo Noise-Cancelling Bluetooth Headphones are both highly-rated at Amazon and affordable at $90, and today they're available at 40% off when you clip the coupon on their product page and enter promo code L2PMZL3U during checkout. That brings their cost down to just $53.99, lower than they've ever reached on their own before.
Utaxo's Noise-Cancelling Bluetooth Headphones feature hybrid active noise cancelling technology which helps to block out ambient sounds around you so you can focus in on whatever you're listening to at the time. They're even nice to have when you simply want to drown out the sounds around you for a little bit of peace from it all. The headphones are equipped with dual 45mm neodymium drivers as well as a CSR chip that work together for impressive sound quality. They also feature an adjustable headband and soft protein leather ear cushions.
With the built-in CVC 6.0 microphone, you'll be able to take calls hands-free; the microphone also has noise-cancelling technology so your voice can be heard more clearly on the other end of the call. The headphones can last for up to 30 hours and take just one hour to charge up. You even have the option of turning off the active noise cancelling technology to conserve battery power, or plugging the headphones in using the included AUX cable to listen for as long as you'd like. At Amazon, more than 250 customers have left reviews for these headphones resulting in a rating of 4.9 out of 5 stars.
These headphones ship for free, though you'd receive your order even faster with an Amazon Prime membership.
