Save on smarts with two Aukey Wi-Fi Smart Plugs for $17
Once you have the smart home bug, it can be frustrating to deal with less-than-intelligent hardware around your home. Pick up two mini Aukey Smart Plugs for just $17 today at Amazon when you enter code GJBI2M2Q during checkout. They'll transform older tech into something more convenient if not completely state-of-the-art. You'll also be saving nearly 30% off their normal cost. Spend $25 or use Amazon Prime and the plugs will ship for free.
Anything you plug into either device will be turned into something that can be controlled with a free app on your phone or using your voice and a smart home helper like Alexa or Google Assistant. All you need is a socket and a Wi-Fi network to set them up. The app allows you to access controls from anywhere to turn something on or off, or check to see if the power settings are where you want them. Plug in a light and ensure your room is well-lit when the sun sets. Use one of the smart plugs with a coffee maker and wake up to a fresh cup of joe. Beat the Monday morning blues by asking Echo to turn off your box fan so you aren't tempted to press snooze again. The possibilities are nearly endless.
Each plug has safeguards built-in to make sure that nothing gets overloaded or short-circuited. Aukey also includes a two-year warranty as well as a 45-day money-back guarantee with your purchase. If you're looking to add more tech to your residence, check out the best smart home products under $50.
Be an expert in 5 minutes
Louryn saves money on everything she buys (which is a lot.) In between waiting for Amazon deliveries, she pines for the next Elder Scrolls installment and checks Reddit for gaming rumors. She also loves Hearthstone, makeup, and beer. Find her on Twitter: @lourynstrampe
