Save over $50 on the Auto-Vox T1400 wireless backup camera kit
Images Deals 2268b2f3 7490 4ebd A89c 6ee315459280 Auto Vox Kit
The Auto-Vox T1400 Upgrade wireless backup camera kit is down to $91.01 on Amazon. You'll get this discount when you clip the $24 off on-page coupon and then use the coupon RNAFIX36 during checkout. The two stacked discounts end up taking just over $50 off the regular $142 price of the kit. We haven't seen a lot of deals on these kits recently, either.
Auto-Vox M1W Wireless Backup Camera Kit
$79.99 $99.99 Save $20
Auto-Vox Dual Dash Cam
$86.79 $139.99 Save $53
Auto-Vox's Dual Dash Cam doesn't just capture what's going on in front of your car but inside it as well. It records in 1080P, features built-in GPS, and falls by nearly $55 when you clip its on-page coupon and use the following code at checkout.
$81.99 $99.99 Save $18
Don't have a backup camera but want one? They do make life a little easier and maybe a little safer for the trash cans and people behind you. The T1400 is actually really simple to setup, too. It uses a wireless transmitter so you don't have to stretch a wire from the rear all the way to front of your car. The reversing image is transmitted wirelessly to the monitor. The signal can reach up to 100 meters, allowing for a super strong transmission and high-definition image with no interference or flickering.
The rear-view mirror will fit most cars. It comes with four different brackets so you can find the right one for your vehicle. It has built-in anti-vibration, too, so you can use it even on bumpy roads. The six LED lights in the rear-view camera will switch on and off based on the ambient light, which is super helpful for seeing in the dark. Backup safely even at night.
Even though the camera is sititng outside your car, you don't need to worry about the weather. The camera is IP68 rated to withstand water and dust. It can also work in extreme temperatures ranging from -13 degrees to as high as 149 degrees.
