Save over 40% on Seneo's Hybrid Active Noise-Cancelling Bluetooth Headphones at Amazon
Focusing on what you're listening to can be difficult when no one around seems to be able to keep their voice down. Thankfully, noise-cancelling headphones are more affordable than ever, so you can grab a pair like the Seneo Hybrid Active Noise-Cancelling Bluetooth Headphones at Amazon and not leave a major dent in your wallet in the process. They're normally priced at $59.99, though today you can snag a pair for only $34.99 when you use promo code SNBH366AH3 during checkout. That's one of the best prices they've ever had, too.
The hybrid active noise-cancelling technology combines two forms of tech, feed forward and feedback noise-cancelling, to block out ambient noise. It's more precise than previous versions and can help drown out the sounds of traffic or machines while giving you a chance to focus on your music.
Get some long-lasting comfort out of these headphones, too, with the soft protein ear cups that can rotate up to 90 degrees to conform to your head. Find the best possible fit with an easily adjustable headband. And, when you're finished, just fold the whole thing together and store it in the included carrying case. Makes it easy to carry with you wherever you go.
As for sound, these headphones have large 40mm drivers. You'll get crisp mids and deep lows with powerful bass. Even while using the Bluetooth tech, you can expect low latency and high-quality Hi-Fi sound. The built-in mic also has its own CVC 6.0 noise-cancelling tech to make sure your voice sounds clear when using the headphones to answer calls.
The battery lasts up to 30 hours on a single charge with the active noise-cancelling turned off. And even when the battery gets low, you can just plug in with the aux cable and go wired. Users give these headphones 4.6 stars out of 5 based on 22 reviews at Amazon.
