OontZ Angle 3 speakers are some of the most popular and well-rated available on Amazon, and today only you can save as much as 50% on a variety of OontZ audio products there while supplies last. The sale includes super-portable wireless speakers, stereo pairs, and even Bluetooth earbuds from as little as $14. All of the items on sale are down to new record-low prices so these are definitely deals you don't want to miss.
Oontz Angle 3 enhanced stereo edition waterproof portable Bluetooth speaker
$20.99 $28.00 Save $7
Plus it uses Bluetooth with a 100-foot range so you can stream from all your devices.
$29.99 $59.99 Save $30
The speaker is well rated, splash-proof, and down to one of its best prices yet.
Oontz Angle 3 portable Bluetooth speaker
$19.99 $25.00 Save $5
Works indoors and outdoors with dust and weather resistance.
The most affordable option in the sale is the OontZ Angle Solo portable speaker at $13.98. This diminutive speaker is surprisingly loud thanks to its 5W of power. It's also IPX5-rated for water resistance making it the perfect speaker to take on vacation for use by the pool or on the beach. It usually sells for around $22. If you want a pair of waterproof speakers, grab the OontZ Angle 3 RainDance 2-pack for $42.99, down $12. These speakers are IPX7-rated meaning they are not only splash-resistant but can actually be submerged without causing permanent damage.
For earphones, check out the OontZ Angle 3 BudZ at $14.99. They've never gone lower and are engineered to offer balanced, distortion-free audio performance at every volume level. They're IPX7 certified too, meaning you can bring them out in the rain or to the gym without worrying about the weather or sweat ruining them. OontZ's proprietary Iso-Fit cushions help to keep the buds comfortable while in use for longer durations, while the built-in rechargeable battery allows you to listen for up to eight hours on a single charge.
These earphones are even equipped with a noise-cancelling microphone that lets you take hands-free calls. There are also in-line controls on the speaker wire to help with switching songs or answering calls. Oontz includes several sizes of In-Ear budZ as well as a pair of Iso-Fit cushions so you can adjust for the best fit.
There are a few other options in the sale, so be sure to take a look at the entire promotion to see what's on offer. No matter what you go for, you'll be scoring a great price on it.
Be an expert in 5 minutes
