Save on four dimmable BR30 LED multi-color smart bulbs with 30% off via Amazon
If you're ready to switch up the lighting around your home, you won't want to miss this discount at Amazon. Right now you can save 30% on a 4-pack of BR30 dimmable LED multi-color smart bulbs and pick them up for just $37.79. The discount is added automatically once you reach checkout, saving you $16 off the set's full cost.
Smart Lights Led Bulb Daylight Aoycocr(6500K) 7.5W A19 - Medium Screw Base (E26) - 750 Lumens(65W equiv.) - Dimmable - RGB Color Changing - Voice Control - No Hub Required - UL Listed - 4 Pack
$20.99 $40.99 Save $20
Aoycocr Smart Light Switch
Starting at $10
These smart light switches can be controlled using an app on your phone or even with your voice! Amazon's offering an additional 50% off which shows at checkout; you can grab one for $10 or two for just $17!
Aoycocr Mini Smart Plug (4-pack)
$19.79 $31.06 Save $11
These smart plugs can be controlled using an app on your phone or tablet, or even with your voice! No hub is required, and today's sale saves you 40% at checkout instantly. That brings them down to just $5 each.
$19.79 $32.99 Save $13
Appliances you already own can be controlled with your phone with help from these mini smart plugs. Adding to your cart via this link scores you 1 for $7.79 or 4 for under $5 apiece.
Aoycocr BR30 dimmable LED multi-color smart bulbs 4-pack
$33.59 $53.00 Save $19
Aoycocr's BR30 smart bulbs are perfect for recessed lighting fixtures and anywhere you need some directional smart lights. Don't require a hub and work with Amazon Alexa and Google Assistant. Set schedules and routines with the free smartphone app.
The Aoyococr bulbs don't require a lot of setup. Just install them like any other light by screwing them in. Then download the Smart Life app and pair your bulb. Follow the instructions, connect to your Wi-Fi, connect to your smart home, and get to customizing. The app gives you the ability to create scenes, set routines, change the colors, set a schedule, and even more. You can even voice control them using Amazon Alexa or Google Assistant; you'll just need a compatible device like the Echo Dot.
These are BR30 bulbs, which means they aren't designed like regular A19 bulbs that fit in standard lamps. The BR30 are directional flood lights that work best when placed in ceiling fixtures or used for recessed lighting. However, Aoyococr also has multi-color A19 bulbs on sale if that's what you need. Prime members can snag them for as low as $5 each, but even without Prime you'll save 40%.
Choose from over 16 million colors when deciding just what color you want your new smart bulbs to be. You can even tune the color temperature from 2700K warm light to 9000K daylight. Match with any other bulbs you have around the room. They are also dimmable from 10% to 100%, which you can adjust without connecting them to a dimmer.
The bulbs should last as long as 22 years with a lifespan of 25,000 hours. Over 230 customers have left reviews for this 4-pack at Amazon resulting in a rating of 4.3 stars out of 5.
