Living with a shoddy Internet connection can be a nightmare. When that old router of yours just isn't cutting it anymore and it's time to upgrade, make sure it's to a system that can adequately cover your home with Wi-Fi for years to come. If that time is already upon you, you're in luck as Amazon is discounting its Eero Pro Wi-Fi Router and Eero Pro Mesh Wi-Fi Systems right now with prices starting from just $159. These limited-time savings allow you to modernize your home internet with one of the most highly-rated systems without breaking the bank, though we don't know how long these deals will last.
Amazon Eero Pro mesh WiFi system bundle
$319.00 $400.00 Save $81
The system comes with one Eero Pro and two Beacons designed to extend the connectivity. Supports up to Wi-Fi 5 and has data transfer rates of 1200 Mbps. Can cover a 2 to 4 bedroom home with reliable internet. Has a mobile app for easy setup.
Eero dual-band mesh networking system 3-pack
$174.99 $250.00 Save $75
Technically $1 more than Prime Day. Sometimes a simple router is not enough to cover an entire house. Hit every room and every corner of the couch with strong Wi-Fi using this. Even works with Alexa. Very easy to install as well.
Amazon eero mesh WiFi - 2 pack
$119.00 $169.99 Save $51
$169.00 $249.00 Save $80
Introducing Amazon eero mesh WiFi router / extender
$69.00 $99.00 Save $30
Eero's Pro whole-home Wi-Fi system replaces your router, and also works as a Wi-Fi extender and internet booster. It's available in a few different configurations with 1 router and 1 beacon, 1 router and 2 beacons, or 3 routers. Prices start at $239 for the kits, which is a $60 savings, and go up to $399 for the top-end set which is $100 off.
The kits can cover homes up to 4,500 square feet in size in reliable Wi-Fi coverage. Not only will you be free from dead zones but, being a tri-band system, Eero Pro also lets you do more simultaneously which is great if you have a ton of connected tech in your home. Eero Pro automatically keeps itself updated so it'll continue working in the background without any difficult legwork required from you either.
If you are already set up with an Eero system and want to expand your coverage, or you want to cover an area of 1,500 square feet or less, you could go for the individual Eero Pro Wi-Fi Router. At $159, it's $40 off.
Whichever you go for, you can easily set up your new Eero system with the help of the free companion app that guides you through the process, and you can use it to monitor your network, set parental controls, run speed tests, and even pause the internet. Time for homework? Want a screen-free family dinner? Turn the internet off temporarily. Should you ever need to expand your network, you can add more Eero products as needed, too.
