Save $50 on the Anker Nebula Capsule portable mini projector
You are now subscribed
Your newsletter sign-up was successful
Great projector deals come around but once in a blue moon, and if you're in the market, now's your chance to save. The black Anker Nebula Capsule Smart Wi-Fi mini portable projector is down to $249.99 today at Amazon. No coupon code is required to get in on the discount. This deal is getting you $50 off the regular price. The projector doesn't drop from its $300 MSRP very often and has only gone below $260 a few times in its history.
Anker Soundcore Life Q30 hybrid active noise-cancelling Bluetooth headphones
$59.99 $79.99 Save $20
These hybrid Bluetooth headphones reduce ambient noise up to 95% thanks to active noise-cancelling mics. The battery lasts up to 40 hours with ANC on or 60 hours with it off, and recharge via USB-C. Clip the $20 on-page coupon.
Anker Powerline II 6-feet USB-C to Lightning cable
$12.74 $15.00 Save $2
When using a USB-C power adapter (not included), you'll get the fastest possible charge for your iPhone. Plus you can seamlessly sync and charge your Mac. This is Apple MFi certified and lasts 12 times longer than other cables.
Anker Liberty Air 2 Pro true wireless earbuds Best Buy
$79.99 $130.00 Save $50
These earbuds have active noise-cancelling that's customizable with a simple app. You'll get a total of 26 hours of playtime with seven hours from a single charge and the rest from the charging case. Uses USB-C and has wireless charging.
Anker Soundcore Rave Neo portable Bluetooth speaker with LED lights
$84.99 $120.00 Save $35
Includes a rechargeable battery that will last for up to 18 hours and can charge other devices with the USB port. IPX7 rated for water resistance. The built-in LED lights will sync to the music you're playing. Connect multiple speakers together.
Anker Soundcore Liberty 2 Pro true wireless earbuds black
$49.99 $100.00 Save $50
They last for up to eight hours on a single charge with up to 32 hours total using the charging case. They have quick charge so you can get two hours after 10 minutes spent charging. They also charge via USB-C or a Qi wireless charger.
The Nebula capsule uses Digital Light Processing and IntelliBright algorithms for a bright, vivid picture that's up to 100 ANSI lumens and 100 inches big. It also has speakers that work in 360 degrees around the device so everyone can hear. The seamless aluminum body only weighs 15 ounces and it can operate for up to four hours on a single charge, so you can take the projector anywhere and watch your favorite shows and movies wherever you want. It even uses Quick Charge tech to get the battery back up and running that much faster. The projector is powered by Android 7.1 so you can stream from your favorite apps like Netflix or YouTube with no trouble.
Of course, not all projectors are created equal. You might want more brightness, a longer battery life, or better sound than the Anker Nebula Capsule can offer. We have a list of the best projectors for you to browse if you're having trouble deciding. Just keep in mind that the Anker deal likely won't last long, so if you're planning on purchasing, do it soon.
Louryn saves money on everything she buys (which is a lot.) In between waiting for Amazon deliveries, she pines for the next Elder Scrolls installment and checks Reddit for gaming rumors. She also loves Hearthstone, makeup, and beer. Find her on Twitter: @lourynstrampe
