Save $50 on the Amazon Echo Plus and get a free smart plug and smart bulb to go with it
Echo Plus on a table
Echo Plus on a table (Image credit: Android Central)
Best Buy has the 2nd-generation Amazon Echo Plus smart speaker for $50 off, and you'll get an Amazon Smart Plug and Philips Hue smart bulb thrown in for free. So not only are you only paying $99.99 instead of $150, you're getting about $40 worth of free stuff.
Ring Video Doorbell Wired with Echo Show 5
$64.99 $139.98 Save $75
The Ring Video Doorbell is bundled with Amazon's Echo Show 5 at over 50% off exclusively for Prime Day. You'll be able to see who's at your door using the Ring app on a myriad of devices, including the Echo Show 5.
Fire TV Stick 4K with 'The Disney Bundle'
Limited Time Only
Exclusively during Prime Day, Amazon is offering Prime members three free months of 'The Disney Bundle' with the purchase of a new Fire TV Stick or Fire Tablet. The Disney Bundle gives subscribers access to Disney+, Hulu, and ESPN+.
Amazon Prime Video Channels
Limited Time Only
Amazon Prime Video lets you add other streaming services as 'channels' to your Prime subscription, and right now select options are down to just $1 per month ahead of Prime Day!
Amazon Echo Devices
Amazon Echo Devices
Prices Vary
Featuring the Echo, Echo Dot, Echo Show 5, Echo Auto, Echo Frames, and more, this sale lets you snap up some Amazon hardware without breaking the bank. These are some of the best prices ever, tough they are just for Prime members.
Amazon Kids+ Family Plan
$0.99 $29.99 Save $29
One of the best deals to come to Amazon Kids+ is now available exclusively for Prime members! Your family can score three months of access for only $1 by signing up before Prime Day begins on June 21.
Amazon's Echo Plus was the first of Amazon's devices to be able to handle the Zigbee wireless protocol. That means of all of Amazon's smart speakers, it is the most robust and capable of handling a lot more than the others. Connect to the Echo Plus via Zigbee, Bluetooth, or by just using your Wi-Fi network. You can control your entire smart home from this device since it has Alexa built right in, too.
Not only that, but the Echo Plus has 360-degree sound with a powerful speaker using a 1.32-inch tweeter and 3-inch woofer. Easily access your favorite streaming apps like Apple Music, Pandora, Sirius, Spotify, and more without breaking a sweat. Of course, you can also use the built-in Chromecast to just send some great tunes to the device from your smartphone. (Youi will get some premium trials to SiriusXM and Pandora with this purchase if that interests you.) You'll even be able to use voice commands to adjust equalizer settings.
You can also use the Echo Plus for hands-free phone calls. Skype calling helps you stay in touch with 150 countries. Drop In is a feature that instantly connects to another compatible Echo or can send an announcement across Echo devices so you can use the Echo Plus like an in-home intercom.
The free Philips Hue smart bulb is one of the Bluetooth versions, so it should instantly work with your Echo Plus. If you want to add more, you'll probably want to get a Philips Hue hub like the one that comes with one of these starter kits.
