Save $45 on Sennheiser's HD 4.50 Bluetooth headphones with active noise-cancellation
The Sennheiser HD 4.50 Bluetooth active noise-cancelling over-ear headphones have dropped to $74.99 at Best Buy. This is a Black Friday sale, which means you can expect a limited supply and limited time for the deal. Other retailers are not selling them this low. The same headphones are $102 at Amazon, $120 at Target, and as much as $130 at B&H. While we have seen these go as low as $70 in the past, that was a very rare discount. The drop to $75 is still really close to the best we've ever seen.
Sennheiser Momentum 2.0 true wireless earbuds
$249.95 $300.00 Save $50
Has 7mm dynamic drivers and an ergonomic design for long-time comfort and powerful sound. Seven hours per earbud with a total of 28 hours from the charging case. AAC and aptX support in combo with Bluetooth 5.1 tech. Noise-cancelling mics.
Sennheiser Momentum True Wireless in-Ear Headphones - Black
$200.99 $299.95 Save $99
$189.98 $299.95 Save $110
Sennheiser is a classic name in headphones, and the company is well-known for its high-quality audio. You're getting that quality with the HD 4.50. The audio includes 18 ohms impedance, a frequency response of 18Hz to 22kHz, and drivers designed with dynamic transducers for reference-grade audio.
It also has active noise-cencellation, which is a great feature for eliminating unwanted noises. The technology will cancel waveforms on the outside of the earcups, which keeps loud noises and other ambient sounds from interfering with the music you want to hear. Take these bad boys on the subway or anywhere you think the surrounding noises might be distracting.
The headphones have a built-in microphone for hands-free phone calls and an over-ear design that securely fits around your ears and preserves your music. Pair with any mobile device thanks to Bluetooth 4.0 technology, and the NFC tech helps you pair with things wirelessly to make life just that more convenient.
It also comes with a carrying case and has a foldable design, which means you can take these headphones with you when you're traveling. The ANC can help drown out the noise of airplane engines, too.
Sennheiser backs these up with a two-year warranty. Users give them 4.4 stars out of 5 based on 211 reviews.
