Save up to 40% today only on smart locks from Schlage, Kwikset, and Defiant
Smart Locks
Smart Locks
Head on over to Home Depot for the Special Buy of the Day, and you'll find a huge selection of smart locks for your home all on sale. You can save as much as 40% off locks from some of the bigger names in the smart lock world, including Schlage, Kwikset, and Defiant. The different locks come in a variety of styles, including simple keyless entry touchpads and larger accent lever door handles. You can even pair the smart locks with matching handles for other doors to give your whole home a consistent look.
The bright bass Schlage Camelot Connect smart lock and handleset is $179.99 during this sale. The lock is smart enough to work with a ton of ecosystems, including Amazon Alexa, Google Assistant, Samsung SmartThings, Wink, and more. It does use the Z-Wave wireless protocol, so you will need something like the SmartThings hub if you want to connect it to your smart home.
The lock includes a modern touchscreen for keyless entry that's also fingerprint resistant so the numbers you press won't be detectable even after repeated use. It also has an ANSI Grade 1 security rating so it's very durable and secure from tampering. There's also a built-in alarm you can set to let you know about potential security threats.
You could also get the satin nickel Kwikset SmartCode 915 touchscreen deadbolt for just $154. The keypad has 1-touch locking and programmable codes for keyless entry to make locking and securing your home as convenient as possible. It installs in just minutes and only requires a simple screwdriver. Plus, the SmartKey Security feature allows you to re-key the lock in seconds. That's something you can do yourself and makes it super easy to change the locks if you ever need to. The deadbolt is resistant to all sorts of common ways of breaking in, including picks, drills, saws, and more.
