Save 40% on the SanDisk Extreme Pro 256GB SD card today only
The SanDisk 256GB Extreme Pro SDXC memory card is down to $59.99 at B&H. Just clip the on-page coupon to save 40% off the cost during checkout. The same card is $70 at other retailers like Amazon and even more in places like Best Buy.
SanDisk Extreme 1TB portable USB-C NVMe solid state drive
$149.99 $240.00 Save $90
Includes a USB-C 3.2 Gen 2 interface for wide compatibility with USB-C devices like computers and smartphones. Has read/write speeds up to 1050 MB/s and 1000 MB/s thanks to the fast NVMe tech. Also IP55 rated for dust and water resistance.
SanDisk 256GB microSDXC memory card
$50.60 $55.00 Save $4
This is Amazon price matching Best Buy. The 256GB card works with any system that can read it and is officially licensed for the Nintendo Switch and Switch Lite. Has read and write speeds up to 100 MB/s and 90 MB/s. Limited lifetime warranty.
SanDisk Extreme Pro 2TB USB-C portable solid state drive
$309.99 $350.00 Save $40
The SSD has powerful NVMe technology with read/write speeds up to 2,000 MB/s. Of course it works with devices not quite capable of that but you won't get speeds as fast either. It comes with a 5-year warranty from SanDisk.
SanDisk Extreme 1TB external USB-C portable solid state drive
$124.99 $140.00 Save $15
Has a 1TB storage capacity and connects easily via USB-C. Even while on the go, you'll get super fast transfer speeds with read speeds up to 550MB/s. The enclosure itself is rugged and resistant to water, dust, and drops. Works with PC and Mac.
SanDisk 1TB Extreme Portable SSD
$155.58 $163.75 Save $8
The SanDisk Extreme Pro can reach a maximum read/write of 170 MB/s and 90 MB/s. It is designed to be compatible with the UHS-I, V30, and U3 standards. These give it the fastest possible speeds for the card. If your device is not compatible with any of these, that's ok. The card can still be used but it will only go as fast as your device's compatibility will allow.
This is a very reliable card. SanDisk says it is shockproof, waterproof, and X-ray proof. It can withstand extreme temperatures and can follow you anywhere, including the pool or the desert. Even if somehow the data becomes corrupted, you can use RescuePro Deluxe. WIth this purchase you get two years of that software to help you save your data. The card also comes with a limited lifetime warranty.
Make sure your device can support SDXC cards before you buy. The high capacity gives you plenty of space for recording 4K video and capturing tons of high-quality photos, even with a time lapse or burst mode on.
