Save $40 on the refurbished HyperX Cloud II gaming headset and hear every sound
Head over to the HyperX Store on eBay and grab the gunmetal HyperX Cloud II gaming headset on sale for $59.99 as a refurbished unit. This refurb comes with a 90-day warranty from HyperX and is in excellent condition. The Cloud II is already considered one of the better budget headsets around, so getting it at this price is a straight bargain. New versions sell for around $100 at most places including Best Buy and Target.
The HyperX Cloud II headset uses a USB audio sound card to create 7.1 virtual surround sound. While it's not actual surround sound, it's good enough that you'll be able tell where noises are coming from. If you're using this to play the latest Call of Duty you'll be able to cut off your enemies from sneaking up on you. Of course, you still got to be good enough to aim, but we can't help you with that.
The sound quality is superb, too, with powerful 53mm neodymium magnet drivers. Puts you right in the middle of the action. The microphone uses an inline sound card and has noise and echo cancelling so your voice is crystal clear to your teammates even with killstreaks and nukes going off on your screen.
The design is super comfortable as well. The headset comes with memory foam ear pads that'll be comfortable and stay comfortable for a long, long time. They even come with an extra set of velour pads so you can replace the original set if they get run down. The microphone is also detachable so you don't have to use it if you don't want it.
The headset is compatible with PC, Mac, Xbox, PlayStation, mobile devices, and more. No matter what platform you use, you can improve your audio experience with this headset.
Be an expert in 5 minutes
