The new AirPods Pro are far from being the only in-ear true wireless earbuds out there worth picking up. Anker's Soundcore Liberty true wireless earbuds work similarly with the ability to activate your phone's smart assistant and even come with a charging case that can keep them powered up for longer than the AirPods Pro, but at a fraction of the cost.
They're normally priced at $90, which is a over $150 below its popular competitor, though today you can grab a pair on sale for just $49.99 at Newegg. All you have to do to score the $40 savings is enter coupon code 93XPJ84 during checkout. At 45% off their regular cost, you'll be scoring these earbuds at one of their best prices in history. The only catch is that this deal is valid for just one day only! Shipping is free.
Anker Soundcore Life Q30 hybrid active noise-cancelling Bluetooth headphones
$59.99 $79.99 Save $20
These hybrid Bluetooth headphones reduce ambient noise up to 95% thanks to active noise-cancelling mics. The battery lasts up to 40 hours with ANC on or 60 hours with it off, and recharge via USB-C. Clip the $20 on-page coupon.
Anker Powerline II 6-feet USB-C to Lightning cable
$12.74 $15.00 Save $2
When using a USB-C power adapter (not included), you'll get the fastest possible charge for your iPhone. Plus you can seamlessly sync and charge your Mac. This is Apple MFi certified and lasts 12 times longer than other cables.
Anker Liberty Air 2 Pro true wireless earbuds Best Buy
$79.99 $130.00 Save $50
These earbuds have active noise-cancelling that's customizable with a simple app. You'll get a total of 26 hours of playtime with seven hours from a single charge and the rest from the charging case. Uses USB-C and has wireless charging.
Anker Soundcore Rave Neo portable Bluetooth speaker with LED lights
$84.99 $120.00 Save $35
Includes a rechargeable battery that will last for up to 18 hours and can charge other devices with the USB port. IPX7 rated for water resistance. The built-in LED lights will sync to the music you're playing. Connect multiple speakers together.
Anker Soundcore Liberty 2 Pro true wireless earbuds black
$49.99 $100.00 Save $50
They last for up to eight hours on a single charge with up to 32 hours total using the charging case. They have quick charge so you can get two hours after 10 minutes spent charging. They also charge via USB-C or a Qi wireless charger.
The Soundcore Liberty earbuds can last for up to eight hours on a single charge, though using the included charging case, you'll be able to keep them powered up for up to 100 hours while traveling without needing another power source. Simply put them away in the case when they're dead to keep them protected and juice them back up.
These earbuds are also designed to fit securely and comfortably in your ears, and thanks to the included ear tips of varying sizes, you can customize them for a better fit. Meanwhile, with Bluetooth 5.0 tech, you'll get music that doesn't lag or skip and still sounds just as HQ as if you're listening to a CD. The one-step pairing instantly connects your earbuds to your device, and you can activate your phone's smart assistant with a single button push, too.
Be an expert in 5 minutes
