Save $22 and improve your audio with Mpow's 2-channel Bluetooth sound bar
You are now subscribed
Your newsletter sign-up was successful
The Mpow 29-inch 2.0-channel Bluetooth sound bar drops to $44.99 with code GGX42OYE at Amazon. This is a relatively new sound bar from Mpow, and we haven't seen any deals on it before. Without the code it's going for its regular street price around $67.
Mpow X5 hybrid active noise-cancelling true wireless earbuds
$39.99 $60.00 Save $20
The hybrid active noise-cancellation on these earbuds uses an outward-facing mic to capture the bad noises and an inward mic to monitor the sound reaching your ears, then uses anti-noise to cancel out the bad stuff. Has 32-hour battery with the case.
Mpow MS1 in-Ear Bluetooth Earphones
$16.99 $29.99 Save $13
These true wireless earbuds come with a charging case that keeps them playing for up to 25 hours while you're on the go. There's also a built-in microphone and IPX7 waterproof nano-coating to keep them protected from runs in the rain and splashes.
Mpow H5 Active Noise Cancelling Over-Ear Bluetooth Headphones
$29.99 $49.99 Save $20
$33.73 $52.99 Save $19
$33.73 $53.99 Save $20
The Mpow sound bar has four two-inch full-range speakers built into it plus two bass reflex tubes. You'll get an audio output up to 95 decibels with powerful bass. If you're sitting there listening to audio played out of your TV speakers, you seriously need to upgrade to at least Mpow's sound bar. It would also make a great option for any TVs in like a kid's room or office or somewhere like that.
You'll find there are plenty of ways to connect to the sound bar either wired or wireless. It has HDMI, aux, optical, and USB inputs. It comes with an HDMI cable, optical cable, and stereo RCA to 3.5mm audio cable for just these sorts of connections. You can use any Bluetooth-enabled device, including your phone or computer, since it has Bluetooth 5.0 tech. The sound bar is compatible with TVs, DVD players, gaming consoles, and more. Play music right off a USB flash drive if you want.
Some of the settings include three equalizer modes (games, music, and movies) that you can switch between using the included remote control. This lets you find the perfect sound for your situation. It also has LED indicators that tell you how it's connected. Place the sound bar right in front of your TV or mount it to the wall. The advanced DSP technology helps provide some exceptional audio clarity along with 3D stereo sound.
Need a TV to plug this sound bar into? Try Vizio's 55-inch 4K HDTV on sale for $498 right now.
