Save $20 and enhance your smart home with TP-Link's 3-pack of Kasa smart switches
Grab three TP-Link Kasa smart light switches for $20 off on Amazon by clipping the on-page coupon. The 3-pack normally sells for $80, so you're saving a nice chunk of change with this deal. A single switch goes for $27, so you're saving more on each one individually in the 3-pack than you would buying them one at a time. If you've got a lot of places around the house you'd like to add some smart connectivity to, this is a great price.
TP-Link Archer AX3000 Wi-Fi 6 wireless router
$99.00 $130.00 Save $31
Wi-Fi 6 promises speeds up to three times faster than previous generations with four times the bandwidth capacity and 75% lower latency. The router has MU-MIMO tech to cover multiple devices connected at once and Ethernet for wired connections.
TP-Link Kasa KP400 smart outdoor plug 2-pack
$29.99 $50.00 Save $20
Get free shipping with your Prime membership. Each plug has two outlets that can be controlled together or individually. Use your phone or voice control with Google Assistant or Amazon Alexa to control them from anywhere. Weather resistant.
TP-Link Archer A20 AC4000 Tri-Band Wi-Fi router
$139.99 $200.00 Save $60
With a tri-band radio, MU-MIMO technology, Beamforming, link aggregation, and more, this router is perfect for homes with a dozen different devices all trying to connect at once. It supports Windows, Mac, and Linux. Includes a 2-year warranty.
$16.99 $25.00 Save $8
With two outlets you can control two outdoor devices either together or individually. And you can do it from anywhere using your phone or voice control through Google Assistant or Amazon Alexa. Weather resistant with long Wi-Fi range.
TP-Link Archer C7 AC1750 Wi-Fi 5 dual-band router
$49.99 $80.00 Save $30
This great little budget router is capable of data transfer speeds up to 1750 Mbps with 2.4GHz and 5GHz wireless bands. Also has four Ethernet ports for a wired connection. Includes a quick and easy setup wizard.
These switches work with Amazon Alexa and Google Assistant for voice control, and you can also control them using your smartphone and the free Kasa app. You don't need a separate hub or anything like that. Just connect to your Wi-Fi network, connect to your smart home, and get going.
Use the smart switches to turn electronics on or off from anywhere in the world. You can also use Away Mode to turn devices on and off at different times, to give the appearance that someone is home. Set up schedules so the lights turn off when you leave and turn on before you get home. Do whatever you want. They're your switches. You can do whatever you want! Set them to turn on and off randomly just to annoy the other members of your house! It's fun.
In order to install these switches, you do need a neutral wire. And they work best in a single-pole setup only. Refer to the user manual, installation guide, and video before use. If you're worried, consult an electrician before trying to do it yourself.
