Save $15 and customize the colors on Razer's Firefly Chroma mousepad
The Razer Firefly Chroma gaming mousepad is down to $34.99 on Amazon. This is $5 above its lowest price drop ever and $15 off what it regularly sells for. For most of the last couple weeks it has been selling for around $52, and it can go as high as $60. The Firefly actually goes as high as $60 at other retailers like Best Buy and Newegg with the next best price being $41 at Walmart. If you prefer a cloth surface instead of a hard surface, you can also get that version of the mousepad for the same $34.99 price.
Razer Basilisk Ultimate wireless gaming mouse with RGB charging dock
$99.99 $140.00 Save $40
One of Razer's most comprehensive mice. Uses HyperSpeed tech so wireless feels as responsive as wired. Has a 20,000 DPI sensor with adjustable sensitivity. Customize the controls of the 11 buttons and the RGB lighting. 70-hour battery life.
Razer Viper Ultimate light wireless gaming mouse
$89.99 $110.00 Save $20
Has HyperSpeed wireless tech for extremely fast responsiveness that makes it feel like a wired mouse. Weighs only 74g so it moves easily. Has a 20,000 DPI sensor for precision that can be adjusted. Eight programmable buttons.
Razer DeathAdder v2 mini gaming mouse
$24.99 $50.00 Save $25
The grip tape gives you unprecedented control over the mouse even during fast-paced gaming. It also has an 8,500 DPI optical sensor with on-the-fly sensitivity adjustment. Use Razer Chroma for custom RGB lighting, too.
Razer Wolverine Tournament Edition gaming controller for PC and Xbox One
$79.99 $120.00 Save $40
Has a rapid-fire switch for instant actuation including a hair trigger mode to reduce the travel distance when pressing triggers. The four multi-function buttons can be remapped. Syncs with popular games and hardware including Razer gear.
Razer Opus active noise-cancelling Bluetooth headphones midnight blue
$149.99 $180.00 Save $30
The ANC in these headphones can detect and nullify incoming noise. They have a 25-hour battery life and are engineered for comfort that entire time with leatherette memory foam ear cushions and a well-balanced weight. Can go wired to save battery.
The Firefly uses a hard, micro-textured finish that helps with both control and speed. The precise, consistant surface gives you great precision and complete control. Whatever mouse you use with whatever settings it has will only improve when used in conjunction with the Firefly mousepad.
Razer Chroma gives you a ton of personalization options for the lighting underneath. You can chioose between 16.8 million colors and customize the lighting effects using Razer's Synapse software. Plus, because it's Razer Chroma and not just basic RGB lighting, you can sync the lights with other Razer gear that also has the Chroma tech. Get your entire PC setup blinking and flashing in sync.
Need a mouse to go with it? Grab the Razer Mamba down to $49.99. That's a sale compared to its regular $90 price and the lowest ever for the Mamba. It also has Razer's Chroma so you can get its customizable colors directly in sync with your new mousepad.
